Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Bent blade My son ran over a metal ground rod with our mower, afterward there was a great deal more vibration than usual. I inspected the machine and it appears the blade is bent. Where do I get a replacement blade?
You should be able to buy a replacement blade @ any local lawn mower repair shop or even @ your nearby Lowes or Home Depot.
Thankyou and have a good Day
Posted on Jul 30, 2008
Why is my electric Black and Decker lawn mower still vibrating and loud after I replaced the blade insulator and fan?
disconnect all power and turn the mower on the side
turn the cutter blade /base by hand and watch the centre bolt or shaft
if it moves in a bit of a circle then it indicates that the motor shaft may be bent, causing the vibration at speed
Aug 03, 2015 | Electric Garden
Mower won't start
If this is a push type mower, most likely is has sheared the flywheel key and bent the bent blade caused the vibration. The blade will need replaced and likely the flywheel key.
May 06, 2014 | Garden
Mower vibrates when blades are engaged
i would inspect the blades one could be bent or have a loose bearing
Jun 20, 2012 | Mtd Garden
Very bad vibration when engaging the blade
Bad vibrations when engaging blades is usually caused by an out of balance blade. Out of balance blades occur due to damaged and/or bent blades. The fix is to find and replace the offending blade.
Jul 19, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Vibrations when the cutting head is lowered . Sounds like one of the blades is hitting the cover. Especially noticeable below a setting of 5. Three cutting blades. There is no noticeable loss of cutting...
Sounds like a bent blade to me. Can you determine where or which side the noise is coming from? For safety, I would replace all the blades. I once ran over my son's baseball while mowing and bent the housing and that caused the blade to hit the side of the deck. I simply bent the housing back with a few hits of a hammer and back to mowing I went.
Jul 04, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Son ran over a large rawhide dog bone with husqvarna rz5424. Blade seem in correct position, not bent but making a terrible racket. Can I reset them somehow or must I take to the mowere repair shop?
It sounds like the spindle is bent.You can remove it to check.Remove the blades,then locate the bolts holding the spindle to the deck.No more than 4 bolts,and it is off.
May 12, 2011 | Garden
Hit steel rod. bent blade. replaced blade, runs but vibrates,bad. and when you try to start it the pull cord, jerks your hand back
probably sheered fly wheel key also check to make sure crank shaft is not bent. lay mower on side air cleaner up remove spark plug wire have some one watch blade bolt while u pull rope bolt should turn with out wobble.
Aug 12, 2010 | Garden
Bent Shaft???
Check that the blade securing bolt is secure. While you're there, have somone SLOWLY pull the starter rope. It will be obvious if anything is bent to the extent you describe.
If this machine has a blade clutch, engage blades while you do the pull test (DISCONNECT PLUG WIRE!!!!)
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower has a loud noise like something is hitting on metal part.changed blade this year with no problems. loud excessive vibration when running.
Sounds like your deck may be bent in and the blade is hitting. Remove the sparkplug and tilt the mower back on the handle (I'm assuming this is a push mower) and have someone pull the rope while you watch the blade underneath. You should see the problem.
Aug 06, 2009 | Craftsman Garden
The engine stalls
you may have trash in the gas tank. empty it nad wash it out real good make sure the gas you use is fresh the vibration could be the blade ; or it could be that when the rock was hit it bent the shaft and that would cause vibration also. remove the spark plug and rotate the blade with your hand, you should be able to tell ifi the shaft is bent or not if not try putting a new blade on
Jun 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
102 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
