DVD Recorder does not play and makes at lot of noise when running.
    Sergeant:
  • 260 Answers
Your problem is most likely going to require a professional cleaning. You should either use our premium service for additional instructions or use a local repair service (see our repair service search button on this page).
You can try to clean the heads by purchasing a head cleaner from a retailer, but what you are describing sounds like a bigger problem.
CH
Posted on Jul 29, 2008
DVD not playing
If your mechanism is making noises it is time to replace the DVD player, not cost effective to repair.
Apr 13, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
U88 displayed on dmr es15 panasonic dvd recorder. cant play ,wipes discs ,makes grinding noises
Took off casing ,removed dvd unit. The laser runs along 2 metal spindles which i lightly oiled with wd 40. next to it runs another brass spindle which i also oiled. Re-assembled , and the machine is good as new.
Nov 14, 2009 | Panasonic Televison & Video
My recorder is making a humming noise and powers on & off
my recorder is making ahumming noise and plays the dvd's but the noise is agrevating
Jun 26, 2009 | Cyberhome DVR 1600 DVD Recorder
Dvd makes strong playing sound. normal?
From the info you have given, your player is probably running a few degrees hotter than usual. This causes the fan to spin at a faster than usual speed causing that noise. It can happen if you keep your player in an enclosed space blocking the heat vents from dispersing the heat. Make sure that you place it in a location where it can disperse heat more easily. This will hopefully resolve the issue.
Apr 22, 2009 | LG DR787T DVD Recorder
DVR making bad DVDs
Three suggestions:
1) take it apart and clean the laser and the spindle 'hub' that the DVD rests on
OR
2) get a 'cleaner' disk that will 'whisk' any dust from the laser diode.
OR as a final suggestion
3) replace the DVD recorder with another. Plain old EIDE parallel interface units fit fine.
This is a very friendly machine in that it will accept PC compatible hard disks and DVDR drives.
tom
Feb 04, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Mechanical Noise in Drive
hii..please go for a change in belt.
thanks..
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Nov 20, 2008 | RCA RTD155 System
Noise while playing VHS
It sounds like the tape is cocked slightly. some VHS tapes did make noise. I'd take it to the store and show them the noise.
Nov 04, 2007 | Philips DVDR3320 DVD Recorder/VCR
Sony DW-Q30A Problem
the dvd writer needs to be replaced,the laser is faulty or miisaligned, the cost of a repair is no longer viable because a new one would cost about $60 (£32.00)
May 30, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
