Question about Canon CanoScan LiDE 600F Flatbed Scanner
White spots on scanned pictures
There are white spots (looks like dust) on my pictures after I scan them and view them at 100%. Have never had this problem previously. Have cleaned the glass carefully and it still appears. Please help!
  • Anonymous Nov 19, 2008
    white spots on scanned photos no dust on photo or glass. Canon is junk!
  • jonhenry Dec 17, 2008
    I just purchased a LiDE 100 it has the same problem. I scanned solid black photo. Looked like a starry night. Customer support was mystified, said it wasn't a known problem but will ship me a new LiDE 100 to replace it. I hope they are not all junk.
  • 883 Answers
SOURCE: After i scan a document, the image appear in black screen. Why?
uninstall the software from pc and turn off. then restart and re-install software.
Posted on Jun 01, 2007
mohanchennai
  • 490 Answers
SOURCE: Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Posted on Dec 11, 2007
old marine
  • 2105 Answers
SOURCE: White spots on scanned photos
There's probably nothing you can do for dust under the glass, but in the Advanced settings for your scanner, there is an option to turn on "Reduce Dust & Scratches", with three different 'strengths'. You may want to try this to see if it helps.
Posted on Apr 21, 2008
SOURCE: CanoScan 5000F foggy glass
No problem.
1st step. Remove the lid. It just pulls out at the hinge end by lifting straight up, horizontal if you like. Where the two lid posts insert in the scanner body you will find 2 screws, undo them, no need to remove at this point, too hard. Rememeber you left them in there though.
2nd step. Around the 4 buttons at the control end is a striped trim panel that is the full width of the scanner. Locate the join between this trim and the light grey underside of the scanner body and just left and right of the COPY & EMAIL buttons, Using your fingernails lift with some gentle force. This edge will pop up. Note, the trim panel has 3 location tabs that insert under the grey border edge around the glass. So pop the front edge first and pull towards yourself.
3rd step. Once this trim is removed you will note 4 little grey plugs equally spaced under this area. remove the plugs and you will find 4 screws. Unscrew them, no need to remove, remember point above.
4th step. Time for CAUTION. You will be able to lift the upper part of the scanner up in which the glass is mounted. ***There is a lead with little play connected to the 4 buttons PCB which is attached to the upper panel. To ensure you don't damage it accidently when cleaning the glass you can remove the 2 screws attaching it to the upper panel.
5th step. See if you can wipe it, with a VERY SOFT LINT FREE cloth, without putting you finger on it somewhere......................
6th step. reassembly is the same in reverse
Posted on Sep 16, 2008
jamie608
  • 32 Answers
SOURCE: How to Clean the inner part of the glass for scanning
Generally you should not have to clean the underside of the glass unless you are in a high dust environment. This would require disassembly of most of the printer itself. The glass is held in by double-sided tape or a bead of glue, so don't try to remove the glass sheet itself.
The easy part is the beginning, removing the scanner cover. Next you will have to locate screws around the outside and start taking panels off. Keep note of the panels and the screws. After the side panels are off, there should be a set of screws around the scanner itself that hold the scanner and plastic casing with the scanner glass. Once those are removed, the scanner glass with its frame should be able to be removed. From there you can use whatever you would like for glass cleaning, make sure it is streak free.
Older scanners make this easier. Most of them are 4-6 screws and the top half pops off and can be easily cleaned. A multifunction isn't so fun in this sense.
Hope this helps!
Posted on Oct 18, 2008
When I try to scan a picture and save it in documents...it scans but shows the picture against a white back drop as if the picture is inserted in a white back drop. When I go to forward the picture it does...
Your scannig software will allow you select the area you want to scan. If you just use the SCAN button on the printer then you will get the full scan.
Mar 18, 2011 | Office Equipment & Supplies
White spots on scanned images
First thing you should do is to check whether the original image is clean and no dust or anything.
The next one is to clean the scanner glass. Use a clean cloth to wipe the scanner glass to make sure there is no dust or anything that might reflect the light from the scanner that can cause white spots.
Please give us update regarding this issue.
Thank you,
Jack
Feb 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
White spots on scanned pictures. how to fix?
better change the glass of your scanner to avoid this problem in thw future and one more thing when ever you are not using the scanner put a soft cloth over glass and cover it or put a A4 size paper it will avoid dust and scratch try this
Jun 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
White cloudy spots on my images - a recent problem
If these are like "bubble" spots and they appear in different places on each photo, I'm guessing you're shooting flash pictures indoors. The spots are dust particles in the air reflecting the flash. This happens on small point-and -shoots because the flash is almost in the same plane as the lens.
Nov 10, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
I have a panasonic kx-mb781 mutilfunction printer,fax,scan,copier and everytime i print i get 2 white lines down the pages every time in the same spot. what could cause this?
Check the spongy black roller inside the machine for dust, wipe with a dry cloth.
Open your document feeder and check for dirt on the white bar.
Sep 11, 2008 | Panasonic Office Equipment & Supplies
White Spot
If this white spot is always exactly the same, but moves off the picture when you start to digital zoom and not optical zoom, there is probably something on the sensor. You mentioned that when zooming, eventually it moves. Are you in digital zoom mode at that time? (The switchover from optical to digital zoom is automatic, but you can disable it). Is this white spot blurry or sharp? Can you see fringes of the image at the edges? (This would suggest something on the lens).
If there is a piece of dust inside the lens ,you may be able to see it looking down the lens. How big is this spot?
Either way, if the camera is new, can you still return it?
May 28, 2008 | JVC GR-D244 DV Digital Camcorder
Vertical white lines in scanned image
Did you try cleaning the little glass strip where the documents go in? Lift the button panel and wipe the glass with rubbing alcohol and cotton swabs or lens paper if you have it. Mine does this sometimes when dust or white out or little bits of paper get stuck on the glass.
Apr 25, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Apr 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Dirty scans
Small white dots would indicate progressive failure of the CCD[sensor] or perhaps ingress of dirt to the inside of the glass. hard to say exactly with out seeing the machine.
Jan 13, 2008 | Epson Perfection 3200 Photo Flatbed...
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
651 people viewed this question
old marine
old marine
