Question about Hotpoint VLXR1020A Top Load Washer
Hotpoint VLXR1020T5WB washer over fills
This wash machine fills to an inch below overflowing before stopping. Then when it aggitates or spins, water everywhere. The air hose is not blocked, I've blown thru it both directions. I've also checked it for leaks. None. I've also tried adjusting the pressure switch to no avail, and even changed the pressure switch. Made no difference. Since there is no air dome on this model, I'm out of ideas. Help!!!
  • 5 more comments
  • Kevkon38 Jul 29, 2008
    There is no water level selection on this model, and the pressure switch has already been replaced. Both the new and old pressure switches test good and click when you blow into the tube. Replaced the pressure switch for lack of knowing what else to do. I've also checked the inlet valve by unplugging the washer while it was filling, and the water stopped like its supposed to.
    Let's try again, shall we?
    Makes zero difference how many clothes in the washer. Even empty it fills to within an inch of overflowing.
    City water, moderately hard. All comes through a whole house filter. No bleach intake.
    Water stops filling the tub when I unplug the machine, or blow through the tube to the pressure switch. An audible click can be heard, and the water shut off completely.
    How can it be the inlet valve stuck open? When power is removed, it closes as advertised. When the pressure switch "clicks", it shuts off as advertised.
  • Kevkon38 Jul 30, 2008
    For the love of.... Does anybody even bother to read what's already been posted? There is not another control panel switch, and since there is no temperature switch (that's encorperated into the timer) it can't possibly be next to it. The pressure switch hose has not fallen off, and the pressure switch has already been replaced. There were no screws holding it in place, and I didn't have to take it to a professional to test it. I have a multi-meter, and can blow into the tube. Water leaks are often difficult to trace? Did you miss the part where I said it doesn't stop filling until the water is only an inch or two from the top of the tub? And where I said it wasn't leaking, but splashes over the side of the tub when it aggitates or spins? All 9 of this person's "recommendations" are for an idiot. Like, if it doesn't work, try plugging it in and turning it on. What a bunch of B.S.
  • 2,071 Answers
Click below that's cause the washer to over fills;
There are 6 'Do-It-Yourselfer' stories about installing this part
Posted on Jul 30, 2008
  • Hotpoint Master
  • 19,396 Answers
What about replacing inlet valve, part replacement here
when is overfilling you have a faulty inlet valve
check also here for reference
Posted on Jul 29, 2008
  • 2 more comments
  • Ginko
    Ginko Jul 29, 2008
    The fact that you unplugged the machine means nothing.
    Check here
    How to Test the Inlet Valve
  • Ginko
    Ginko Jul 29, 2008
    And remember to vote the solution if you fix it
  • Ginko
    Ginko Jul 29, 2008
    It clicks but it does not shut off, the inlet valve it's no longer able to shut off completely when the electricity has been turned off to it.
    This is a typical case, there is no much else to say.
  • Ginko
    Ginko Jul 29, 2008
    On some model the water level switch causes the problem, in this case you do not hear the click. Inlet valve and water level switch are the two faults that can cause overfilling.
    I report here from repairclinic, but any basic WM troubleshooting will tell you the same:
    It's overfilling
    If your washer is overfilling, check these:
    Water-inlet valve
    Water-level switch
    Water-inlet valve
    A
    defect in the water-inlet valve may mean that it's no longer able to
    shut off completely when the electricity has been turned off to it. If
    this occurs, the valve may leak and drip water into the clothes tub. In
    time, the water may accumulate substantially. If this happens, you need
    to replace the valve.
    Water-level switch
    A
    defect--or an obstruction--in the water-level switch may mean that it
    can't tell the water to shut off. So the machine overflows. This switch
    senses the water level in the clothes tub. It's usually a diaphragm
    device with a small, clear tube attached between the switch and the
    bottom of the washer's outer tub. As the water level in the tub
    increases, the pressure on the air in the tube increases. When the
    pressure reaches a certain level, it activates the switch, shuts off
    the water, and signals the timer to begin the agitate cycle. You can
    either clear any obstruction in the tube or replace the water-level
    switch."
    Genius:
  • 1,665 Answers
Better have an authorized repairman to inspect and figure out which part is faulty to replace.
    Sergeant:
    Champion:
  • 214 Answers
Its inlet valve problem
    Master:
  • 623 Answers
There is another control panel switch, usually located next to the temperature switch. There is a small hose connected to this switch, and sometimes this hose becomes loose and falls off the connection. When this happens, the water in the tub usually overflows. To solve this problem, cut about 1/2 inch off the end of the hose and use a push fit to reconnect it to the switch.
The switch itself can also malfunction, resulting in tub overflow and other water-level trouble in the tub. If you suspect this switch is faulty, remove it by backing out the screws holding it in place. Take it to a professional service person for testing. If the switch is faulty, replace it with a new one of the same size and type. Connect the new switch the same way the old one was connected.
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
1: Check the lid seal. If faulty, replace with a new gasket.
2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
4:
Check the drain hoses. Tighten connections or replace hoses.
5: Check the inlet nozzles. Tighten connections or replace nozzles.
6: Check the splash guard. Tighten connections or replace.
7: Check any plastic valve. Tighten connections or replace.
8: Check the outlet hose to drain. Tighten connections or replace hose.
9:
Check the water pump, using the procedures that follow
    Master:
  • 726 Answers
Nope its the inlet valve stuck open %100 sure
    Sergeant:
  • 260 Answers
If it is overfilling the problem is likely a switch that will have to be replaced. One way to determine if this is the cause is to set water level to medium or low. If it still goes way above the normal low or medium level, then you need to replace the switch. We recommend a local repair service or warranty work.
  • Ken Jones
    Ken Jones Jul 29, 2008
    You are correct about the switch.
    I still recommend trying a small load to see if it still overfills.
    When pressure switches are used then the water put in the load is based on the amount of laundry put in the washer.
    First, wash a load that is nearly empty.
    Then wash slightly larger loads and work your way up.
    If you are still spilling water on small loads then the problem is the washer.
    If you are not experiencing this problem on smaller loads then it is likely that you are putting too many clothes in the washer.
    Before you call a professional, make sure your bleach, fabric softner and detergent inlets are connected securely.
  • Ken Jones
    When this problem occured on my father's machine we fixed it by replacing a faulty bleach intake connection. please make sure that is not your problem as well.
    Is your water hard or soft? sandy, silty, clean, etc.
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
My washer overflowed and now it won't fill up with water or spin but it still aggitates how do i fix it?
I am surprised that it agitates? The overflowing indicates that the water level pressure switch is not working. This is located at the back of the unit in the control panel. It looks like a round item with two wires attached as well as a plastic tube going down to the bottom of the drum. Try replacing it, I am sure this will sort your problem.
Nov 18, 2009 | Hotpoint VBXR1090D Top Load Washer
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Feb 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
Sep 01, 2008 | Maytag PAV2300 Top Load Washer
Overflow
If you unplug the machine and the water still comes in, you have a bad Water Inlet Valve. If when you turn the machine on at in overfills and you can stop the water by turning off the washer timer then you have one of a couple possible issues.
First, you pressure sensing tube could be clogged
Second, you just plain have a defective pressure sensing switch.
If you have anymore questions, feel free to comment back.
Thank you
Mar 26, 2008 | Hotpoint VBSR3100D Top Load Washer
Water won't drain out
Possible lid lock, check the lid is locked when it should be spinning or pump jammed and check the draim filter. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint VLXR1020A Top Load Washer Logo
191 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
