Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Ultravision image dark
The image seems to be dark on my set. After the original I have replaced two bulbs with the exact same kind and still have the dark picture. Example: Watching a movie that has a night scene you cannot see anything.
  • whizzeron Jan 25, 2009
    We changed the bulb but since then our picture is so dark we can't see the picture espcially on night scenes in movies. We think that maybe this bulb was not as bright and now ordered another bulb. Is the contrast problem because of bulb? We are worried that a new bulb won't change problem, then what? We did change settings for brightness and contrast but there was no difference. It also seems that it takes screen more time to warm up to even see the picture. HELP.
  • arayjr1231 Mar 14, 2009
    DARK PICTURE AFTER CHANGING THE BULB IT WAS OK BEFORE
  • 927 Answers
Good Day, tfarmer;
Since you have replaced the lamp, which is the normal cause for a dark picture. Have you checked your video settings?
The brightness level should be set at about 55 to 60%, the contrast should be set at about 90% and the video temp should be at normal or high.
If all these are set about this way, then I would think that the light engine might be going bad.
Good Luck, big IRISH.
Posted on Aug 02, 2008
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
Picture is very dark on all channels. Settings have not changed. Do I need to replace the bulb?
You may need a drive PCB. This PCB can cause the picture to be too bright, no brightness or picture too dark, intermittantly or permanantly. Do check the bulb though and see if it is foggy looking or dull especially if it has not been changed. Thanks for using Fixya.
Oct 27, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Monitor acer lcd AL1717a
Looks like you have a burned lamp.
Most LCDs have a lamp that lights the screen's image.
If you see the image, but its too dark.....you need a lamp replacement.
Please rate this answer if its useful
Jun 18, 2009 | Acer AL1715 17" LCD Monitor
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
Feb 19, 2009 | Samsung HL-R5668W 56" HDTV
50" Hitachi Ultravision with yellow picture
Good Day, steveb13;
It stills points to yhe Light Engine. Good Luck, big IRISH.
Jul 15, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi projection 53" screen color off
Since this is a CRT based projection set, there is no "lamp" involved. Does the picture look like 3-D? If so, the problem is likely to be a convergence problem. There should be 1 or 2 convergence ICs marked STK392-110 inside attached to a heatsink. If you can solder, try resoldering the pins on those ICs. If that fails to resolve the problem, replace them.
Keep us posted.
Dan
Jul 14, 2008 | Hitachi 53UDX10B 53" Rear Projection...
LCD TV picture screen very dark
I have the same issues with my Westinghouse LCD set. I've found that going into the settings (using the TV remote) I can get it back to a bright picture by selecting 'restore factory settings'. It is aggravating and a pain, but I can correct it.
It only seems to do it on the analog stations, not the digital (HD) ones, so maybe it will go away after the conversion next year.
Hope this works for you.
Feb 18, 2008 | Televison & Video
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
391 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
