Question about RCA HD52W56 52" Rear Projection HDTV
How to remove fuse
I have the RCA R52WH77 projection TV with the ITC22A chasis. I am wondering how to remove the fl231 fuse. The brown cover came off ok but unsure how to remove the fuse. I lost the convergence menu from the options screen and was told to check this first before anything else.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Solder will have to be removed from component solder side..
Posted on Jul 31, 2008
Tip
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC222 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
2. Remove the back. there a number of torx 20 screws.
3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
5 when you get the tray up the bottom side of the board can be accessed
you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
6. REPLACE FUSE RCA PART 259213
7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
8 reassemble set. make sure you examine the set for loose connections.
9 and remember "BE Careful'
on Sep 20, 2008 | RCA R52WH73 Projection Television
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
RCA picture not aligned and cant find in menu
iwould guess you might have the fl231 fuse problem check und tips and trick section in my profile and read the article
Jun 19, 2009 | RCA Televison & Video
RCA 52 INC MODEL R52WH77
From the symptoms you describe. you have the fl231 fuse problem. Congrations this is a simple fix. please read my article "the fl231 fuse problem" in the tips and tricks section
Apr 13, 2009 | RCA HD52W59 HDTV Projection Television
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
No Convergence
yes that model is the same itc222 chasis... the fl231 problem is common on all itc222's even more so on that model .. consult the tips and tricks section for the fl231 problem repair instructions
Jan 11, 2009 | RCA R52WH73 Projection Television
RCA HD52W59 Distorted colors and bowed pic.
in customer menu under setup do you have the convergence option. If you do not it probally be that fuse. this fuse is located on the main defection to the right of what know as flyback.. which is a large black component with two large red wires coming from it.
Nov 07, 2008 | RCA HD52W59 HDTV Projection Television
Rca 52inch hdtv
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
Sep 27, 2008 | RCA HD52W59 HDTV Projection Television
Tv help!!!!
ok to replace that board you have to have the entire model number. it will be on the label in small letters it will be likke r52wh77yx1 or ......yx38 or something like that ...this is critical in getting the right part
Sep 09, 2008 | RCA P52937 52" Rear Projection Television
RCA HD52W56 52" Rear Projection HDTV Logo
226 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
