Question about Kyocera Cell Phones
My Keyocera K312 has a personal 4 digit keypad lock. I can turn on the phone, but can't really do anything else. How do I get rid of this?
I have assigned a personal 4-digit pin to unlock my phone evrytime I turn it on. One time my pin would not unlock the phone and for a couple days I couldn't use my phone. I just started punching in differnt codes and discovered it has a default unlock code 0000. Give that one a try as it should unlock your phone.
Posted on Aug 04, 2008
How to reset anti theft system
KEYLESS ENTRY SYSTEM You can use the keyless entry keypad to:• lock or unlock the doors without using a key.• open the trunk.• recall memory seat/mirrors/steering column/adjustable pedals positions1 or 2. The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner's wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also create your own 5-digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation. Programming a personal entry code. To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. Note: The lock motors will cycle, locked then unlocked 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. Enter a sixth digit to indicate which personality feature should be recalled by the personal code. Note: The lock motors will cycle, locked then unlocked. • 1 • 2 recalls driver personality 1. • 3 • 4 recalls driver personality 2. • 9 • 0 does not recall a driver personality. Wait 5 seconds without pressing a keypad button in order to store a personal entry code. Tips: • Do not set a code that uses five of the same number. • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. • If you set a personal code and store it over an existing personal code it will erase that personal code only. Erasing personal code 1. Enter the factory set 5-digit code. 2. Press and hold the 1 • 2 for two seconds and release; this must be done within five seconds of completing step 1. 3. Press and hold the 1 • 2 for two seconds to erase the customer programmed code; this must be done within five seconds of completing step 2. Your personal code is now erased and only the factory set 5-digit code will work.
Feb 09, 2011 | 2002 Lincoln LS
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
I don't have a manual for my 2004 lincoln Avaitor but would like to know how I can change the code on the drives door key pad
KEYLESS ENTRY SYSTEM With the keyless entry keypad, you can: • lock or unlock the vehicle doors without using the key. Your vehicle has a factory set 5 digit code that operates the keyless entry system. You can also program your own 5 digit personal entry code. The factory-set code is located: • on the owner's wallet card in the glove compartment • or at your dealer. When pressing the controls on the keyless entry keypad, press the middle of the controls to ensure a good activation. This system will disable the power door lock controls. These will not work until the vehicle is disarmed. Programming your own personal entry code To program your own code: 5. Enter factory set code (keypad will illuminate when pressed). 6. Press 1/2 control within five seconds of step 1. 7. Enter your personal 5 digit code. Enter each digit within five seconds of previous one. 8. After the code is entered, the locks will cycle, confirming that the new code has been set. Do not set a code that includes five of the same number or presents them in sequential order. Thieves can easily figure out these types of codes. Your personal code does not replace the permanent code that the dealership gave you. You can use either code to unlock your vehicle. If a second personal code is entered, the module will erase the first personal code in favor of the new code. Locks and Security 149 Locks and Security If you wish to erase your personal code, use the following instructions: 1. Enter factory set code. 2. Press 1/2 control and release. The system will now only respond to the factory set code. Anti-scan feature The anti-scan feature prevents repeated attempts at arriving at a valid key code. The keyless entry pad is disabled for 1 minute after 7 unsuccessful attempts (35 consecutive button presses) at entering a valid key code. The keypad will flash during this 1 minute mode. However, the 7/8 and 9/0 controls will still lock the vehicle. Anti-scan will be turned off after: • one minute of keypad inactivity. • the remote entry transmitter UNLOCK button is pressed. • the ignition is turned to the ON position. Unlocking the doors with the keyless entry system To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will also illuminate. To unlock all doors, enter the factory set code or personal code (driver door unlocks) and press the 3/4 control within five seconds. Locking the doors with the keyless entry system It is not necessary to enter the factory or personal code prior to locking all doors. To lock the doors: • with the driver's door closed, press the 7/8 control and the 9/0 control at the same time.
Dec 17, 2009 | 2004 Lincoln Aviator
I WANT TO LOCK THE KEYPAD OF MY PHONE.
hi,
the keypad lock password is located on Settings, Security, Locks, Inactivity Lock. Defualt Phone Lock Password is 0000.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sony Ericsson W760i Cellular Phone
Need to reprogram key less entry. 2002 Ford explorer sport.
Keyless Entry Keypad FAQ Ford Explorer
  • Lock or unlock the doors without using a key.
  • Open the liftgate window.
  • Activate or deactivate the autolock feature.
Where the code can be found
  • This code is located on the owner's wallet card in the glove box
  • Is available from your authorized dealer via scan code
  • Is marked on the computer module
Computer Module location
  • 1995 thru 2001 is located in the jack storage compartment in the rear of your Explorer. First remove the panel to the jack storage compartment. Towards the front of this area you should see a metal box this is your auto-lock module(way up front next to your rear left passenger seat). On the back side of this is your 5 digit code factory preset code. It is hard to get to. To see it you will have to loosen, pull, use a flashlight or a mirror but it can be done.
  • 2002 thru 2007 is in the right panel behind the middle row window. It is below the seat belt mechanism. You have to pull out the top plastic panel off, then loosen the lower panel to be able to see the face of the computer module. The code is on a sticker on the face of the module.
Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5�digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
  • 1. Enter the factory set code.
  • 2. Within five seconds press the 1 � 2 on the keypad.
  • 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
  • 4. Press 1 � 2, 3 � 4 or 5 � 6 to indicate which of the three personal entry code positions you wish to use.
  • 5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
Tips:
  • If you program a code to a position that already contains a set code, the previously-set code will be erased.
  • 1. Enter the factory set 5�digit code.
  • 2. Within five seconds, press the 1 � 2 on the keypad and release.
  • 3. Press and hold the 1 � 2 for two seconds. This must be done within five seconds of completing Step 2.
All personal codes are now erased and only the factory set 5�digit code will work.
Anti-scan feature If the wrong code has been entered 7 times (35 consecutive button presses), the keypad will go into an anti-scan mode. This mode disables the keypad for one minute and the keypad lamp will flash.
The anti-scan feature will turn off after
  • One minute of keypad inactivity.
  • Pressing the UNLOCK control on the remote entry transmitter.
  • The ignition is turned to the 3 (ON) position.
Unlocking and locking the doors, liftgate and liftgate window using keyless entry
  • To unlock the driver�s door, enter the factory set 5-digit code or one of the vehicle�s personal codes.
  • Each number must be pressed within five seconds of each other. The interior lamps will illuminate.
  • To unlock all doors and liftgate, press the 3 � 4 control within five seconds.
  • To open the liftgate window, press the 5 � 6 control within five seconds.
  • To lock all doors, liftgate and liftgate window, press the 7 � 8 and the 9 � 0 at the same time.
  • Note: The driver�s door must be closed. You do not need to enter the keypad code first.
Deactivating/activating autolock
  • Your vehicle comes with the autolock feature enabled.
Note: The autolock feature can be activated/deactivated independently of the autounlock feature.
Before following the activation or deactivation procedures, make sure that the anti-theft system is not armed, ignition is in the 1 (OFF/LOCK)position, and all vehicle doors, liftgate and liftgate window are closed.
*Keyless entry key pad procedure
  • 1. Turn the ignition to the 1 (OFF/LOCK) position.
  • 2. Close all doors, the liftgate and liftgate window.
  • 3. Enter 5�digit entry code
  • 4. Press and hold the 3 � 4. While holding the 3 � 4 press the 7 � 8.
  • 5. Release the 7 � 8.
  • 6. Release the 3 � 4.
The user should receive a horn chirp to indicate the system has been disabled or a chirp followed by a honk to indicate the system has been enabled.
Autounlock The autounlock feature will unlock all the doors when: � the ignition is in the 3 (ON) position, all the doors are closed, and the vehicle has been in motion at a speed greater than 12 mph (20 km/h); � the vehicle has then come to a stop and the ignition is turned to the 1 (OFF/LOCK) or 2 (ACC) position; and � the driver door is opened within 10 minutes of the ignition being transitioned to the 1 (OFF/LOCK) or 2 (ACC) position.
Note: The doors will not autounlock if the vehicle has been electronically locked before the driver door is opened.
Deactivating/activating autounlock - Keyless entry key pad procedure Your vehicle comes with the autounlock feature activated.
  • 4. Press and hold the 3 � 4. While holding the 3 � 4 press the 7 � 8 twice.
The keyless entry touch pad can use two codes. The factory code and one
personal code .
To program your own personal code, select a 5 digit code that doesn't use 5 digits in
sequence or the same button 5 times.
Enter your factory code
Within 5 seconds press the 1/2 button
Within 5 seconds of pressing the 1/2 button, enter your 5 digit personal code,
pressing each digit within 5 seconds of the previous digit.
You can now use either code to operate the keypad
Setting FOB to work with your vehicle
  1. Sit in car, doors closed. Electronically unlock all doors using the power door unlock switch on the driver's door.
  2. Insert key into ignition switch and turn from OFF to ON 8 times within 10 seconds with the 8th time ending in the ON position. (5 times on some models)
  3. The doors should lock and unlock by themselves to signal programming mode.
  4. Using your remote: lock the doors.
Sep 16, 2009 | 2002 Ford Explorer Sport Trac
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Lg dare keypad is locked
Is your keypad locked where it wants a 4 digit pin try 4 zeros or the last 4 digits of your phone i work for verizon so let me know whats going on will figure it out..
Thanks,
Steve
Jan 05, 2009 | Cell Phones
Helppppp unlock code for side id from tmobile
http://shop.sidekickskin.net/Sidekick-Tips-Tricks
This tip unlocks the 3 digit security lock.
1. at the same time hold the menu button (top left) and the jump button (bottom left)
2. This will bring you to the emergency screen (it gives you the option to make an emergency call)
3. Open to the keypad and hold in the menu+shift+q buttons at the same time.
4. The phone will reset and clear/unlock the security code
Mar 30, 2008 | T-Mobile Sidekick ID Cellular Phone
Unlock kyocera k312
Master Code my ime 352272010819661
Jan 27, 2008 | Cell Phones
Cell Phones Logo
103 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
