Fujitsu M4099D You helped me a few weeks ago with a lamp problem. This scanner is new to us. I had a quick question. The specs say it should scan 90 PPM or 180PPM if on duplex. We are only getting 24 PPM. Any ideas why it is much slower the the specs are calling for. thanks
  • 25 Answers
What resolution are you at? When scanner manufacturers rate their scanner at a given speed, it is usually :
1. at 200dpi or lower
2. landscape mode
3. plenty of ram on the pc
4. most image enhancements turned off.
If you are running at 300dpi, you scanner will slow down considerably. You can set this is your software, but also check thru the front panel.
You probably won't get 90 ppm in reality, just as you usually won't get the gas mileage posted on the new car sheet ! But you should get at least 70ppm.
Check your operator's manual to access the front panel menu.
Posted on Jul 30, 2008
Scan snap won't work
This is a known problem with Fujitsu ScanSnaps. Some units experience the "blue button of death" meaning they no longer respond to waking the driver up when you press the blue button. Customer service is aware of the problem and if you are under warranty you should be able to get a new unit.
Mar 21, 2012 | Fujitsu ScanSnap S1500 Instant PDF...
How many lamps are in fujitsu 5750c scanner? how can i replace them?
Hi Albert,
There are two CCD lamps inside Fujitsu fi-5750c Duplex scanner.One is ADF Front and the other is ADF Back.To replace them, you may need the help of Fujitsu certified technician, for the procedure requires technical expertise.
Thanks & regards,
ScanCare
Nov 08, 2011 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi 4750c scanner error
Try a flatbed scan scan with the cover open.  If you see the lamp come on, it's likely a cable or CCD problem, though it can be caused by a really dirty reference strip or mirrors. I've never seen one that dirty but it's mentioned in the service manual. I have seen lost documents in the ADF unit cause backside optical alarms, but the front unit is protected from this by glass. If the lamp doesn't light, it can be a defective lamp or cable. In all these cases, you'll need a tech onsite. Disassembly of this model is difficult & reassembly is even worse. I wouldn't recommend it even if you're mechanically inclined.
Apr 07, 2009 | Fujitsu fi-4750C Flatbed Scanner
Fujitsu Scanpart 620c Leds error Amber on, Green blinking,red bli
Thank you for contacting Fixya.
You need to check the blinking times of the Paer jam LED. Then check the followings:
1. If the lamp is on, then ADF Switch is malfunctioning. Disble or short the switch.
2. If the lamp is off, then it is Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
5. If the Lamp is still off, then Lamp is to be replaced.
6. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Hope the above information is helpful.
Please revert if you have any doubt.
Regards,
TechSatya
Mar 26, 2009 | Fujitsu ScanPartner 620C Flatbed Scanner
M4099d scanner
Attributed to paper sensor problems.
Clean the little square and round paper sensors under swing arm of
upper feed roller asm.
also clean the clear plastic return reflectors.
these may need changing as they taint after time.
Jan 12, 2009 | Fujitsu M4099D/FI-4990C Scanners
Fi4990C
When the scanner scans the first image it will bring in via a set of solenoids a background white Reference metal flap for both rear and front cameras.
The above error comes about when the solenoids are sticking or they have magnetised themselves.
1.Clean the Solenoids.
if scanner still errors .
2. Replace solenoids.
Dec 30, 2008 | Fujitsu M4099D/FI-4990C Scanners
How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Oct 27, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu M4099D
The Rom board is the big circuit board that can be removed from the rear of the scanner. I think there are about three screws that secure the plate that surrounds the output jacks. With the screws out, the whole rom board comes out like a sliding tray. The fuses are round and brown in color. BUT warning! Don't mix them up because they are of different values. If you try swapping them around, you will put the wrong value in another slot and it will blow! If your lamps are lit, then the fuses are ok, but try pulling the circuit board tray out and reseating the tray.
If the lamps are lit, then the fuse and lamp inverter is ok. If you swapped the cameras, and the problem still says its the front lamp, make sure that the lamp is turned around to its proper position. The lamps are masked with a clear opening. If that opening is not turned to shine the light at the right position, you could be getting the alarm because of the loss of light.
If the problem shifted to the rear lamp alarm when you switched the cameras, then the camera mirrors are real dirty inside or its just a bad camera.
Jul 11, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Fujitsu M4099D
Sounds then like a loose camera cable , dirty glass, or white background plate.
Fujitsu M4099D
First, you didn't say whether the Front lamps are actually lit. I know that it is difficult to tell on this model unless you cheat the lamp interlock switch and fire up the unit into scan mode.
Front Lamps errors can also be generated by a loose front camera cable. There are no dedicated lamp detectors. The 4099 uses the camera's ccd's to detect if the lamps are burning. It is also possible, but less likely , that the lamp fuse on the main board (slides out from rear) is blown. (Fuse part number CA53004-0227).
From previous experience, there is probably a 95% chance that the issue if coming from a loose front camera cable. Not the kind of thing to get in and check unless you are service savy. I have had several calls that drove me nuts with this issue until I reseated that cable onto the camera.
The Fujitsu service manual list these possibilties :
a. Do the Front side lamps lite up when you attempt to scan?
b. Is the lamps correctly seated?
c. If the lamps don't light up, possible lamp inverter problem or fuse problem.
d. Is the glass surface and white sheet guide clean?
e. Are the connectors at the front camera ccd loose?
f. Is the power supply output normal?
g. Possible front camera failure.
h. Possible connections from camera to the Rom board problem.
165 people viewed this question
jasbo
jasbo
