Question about Compaq Armada M700 Notebook
Memory overload i let my son use my laptop and he downloaded all kinds of when i turn it on it says isass.exe/system error insufficient system resources exist to complete the API.
  • mh5591 Jul 29, 2008
    already tried it and it restarts back to the same errror need a way to bypass the eror so i can free up some space
  • 216 Answers
Greetings mh5591,
What this means is there currently is not enough hard drive on the unit to boot up windows. If there's not enough free space on your hard drive, Windows won't open. Try accessing through Safe Mode and see if you can create the necessary room. Boot the system, start tapping F8, when the menu appears, select
Safe Mode and press enter.
I hope this helps.
Go Ahead. Use Us.
Posted on Jul 29, 2008
Isass.exe system error keeps coming up, insufficient system resources exit to complete the API
1. Remove all viruses or spyware or worms, if there are any.
Open Task manager and check how much physical memory and PF (Paging file) is being used.
2. If usage of both physical memory and PF (Paging file) is high
Click start>> Control Panel >> System >> Advanced >> Performance Settings
3. Click on Advanced tab and click Change under Virtual Memory.
Click Custom size and set the Initial size to 1.5 times of the RAM size on the computer and Maximum to 3 times.
4. Restart the computer
5. Empty some memory space on the "C" drive
6. Click Start >> Run >> Type CMD >> Click OK
7. In command prompt type "chkdsk /r" press "Enter"
8. Type "Y" and press "Enter"
9. Restart the computer
10. Also if you want you can defrag
Sep 19, 2010 | Acer Aspire One PC Notebook
HP - Compaq 6310P Laptop that Is giving an Isass.exe system error
As you may know, lsass is; Local Security Authentication Server. ANY OF THESE THINGS CAN RESULT IN AN UNUSABLE SYSTEM! So don't try them if you aren't able to re-install your operating system without trashing it (Over top should work), if there's any information not backed up that you can't lose, or aren't prepared for the worst, because that's what usually happens, right? :^D TAKE IT TO SOMEONE IF ANY OF THESE THINGS APPLY TO YOU.
Although you shouldn't have any problems with these simple remedies, I don't want to be responsible if it does!
The trojan you found and removed has corrupted some registry settings.
If you have a known good configuration, you can "go back". OR you can try running a registry cleaner on it.
You can also try going into "Services" and killing it, which should bring up your Welcome screen and reboot. All of your usernames and passwords may be gone though! And you'll have to start over.
Sep 02, 2009 | Computers & Internet
Isass.exe - System Error
Its seems like some of the windows files are corrupted, you will need to repair windows.
You need a windows xp cd to do
Good Luck!
Mar 27, 2009 | Computers & Internet
Spysweeper program damaged after a.exe download
isass.exe is registered as the Optix.Pro virus which carries in it's payload, the ability to disable firewalls and local security protections, and a backdoor capability
How Do You Remove Isass.exe Files in Windows XP and Vista:
  1. Click your Windows Start menu, and from “Search,” click “For Files and Folders….”
  2. A speech bubble will pop up asking you, “What do you want to search for?” Click “All files and folders.”
  3. Type a Isass.exe file in the search box, and select “Local Hard Drives.”
  4. Click “Search.” Once the file is found, delete it.
How to stop Isass.exe processes:
  1. Click the Start menu, select Run.
  2. Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys ALT + CTRL + DELETE or CTRL + Shift + ESC.
  3. Click Processes tab, and find Isass.exe processes.
  4. Once you’ve found the Isass.exe processes, right-click them and select “End Process” to kill Isass.exe.
How to remove Isass.exe registry keys: (Do not delete anything other than what is listed below.)
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any Isass.exe registry keys, select “Edit,” then select “Find,” and in the search bar type any of Isass.exe’s registry keys.
  4. As soon as Isass.exe registry key appears, you can delete the Isass.exe registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
How to delete Isass.exe DLL files:
  1. First locate Isass.exe DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the Isass.exe DLL file is located. If you’re not sure if the Isass.exe DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the Isass.exe DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore any Isass.exe DLL file you removed, type “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Did Isass.exe change your homepage?
  1. Click Windows Start menu > Control Panel > Internet Options.
  2. Under Home Page, select the General > Use Default.
  3. Type in the URL you want as your home page (e.g., “”).
  4. Select Apply > OK.
  5. You’ll want to open a fresh web page and make sure that your new default home page pops up.
Block Isass.exe sites:
Stop Isass.exe processes:
Get rid of Isass.exe DLLs: %PROGRAM_FILES%\ eKerberos\ Hook.dll
Delete Isass.exe folders: %PROGRAM_FILES%\ eKerberos\
Please rate this a fixya
Feb 08, 2009 | Webroot Spy Sweeper (spysweeper) for PC
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
Dialog box
Does the dialog box say Isass.exe not found !!! If so then it was corrupted by a virus and ur antivirus did a bad job of cleaning it... it modified/deleted it. Isass.exe is a system/servicecontrol file. If u have another pc copy Isass.exe from it..... Isass.exe is found in C:\Windows\System32
Oct 27, 2008 | Acer TravelMate 2300 Notebook
Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
Oct 12, 2008 | Acer Aspire 3680 Laptop
Acer travelmate 2300
it indicates a virus..would suggest you to take backup of your data if possible and reinstall the os
Feb 29, 2008 | Acer TravelMate 2300 Notebook
Compaq Armada M700 Notebook Logo
91 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
