Question about Audio Technica ATW-T52 Professional Microphone
HELP I NEED A NEW TECHNICA ATW-T52 MIC OR A NEW MIC HEAD
  • 1 more comment
  • STEVEBILLSON Jul 30, 2008
    guitar center ????????????????
  • Ron Badgerow
    Ron Badgerow Oct 26, 2013
    Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
  • Anonymous Mar 30, 2014
    But I have a small problem with the 9V battery draining little bit faster.
    May I know how much current (mA) should take the Mic Tx when it is working.
    As I have noticed its draining approximately 100mA.Is this normal ?
    Is there a way to drop this figure(100mA) bit lower?
    New Friend:
Posted on Oct 26, 2013
    Problem Solver:
  • 20 Answers
U can go to guitar center and but a new one
Posted on Jul 29, 2008
Wiring for atw-t52
The other is most likely a ground. However you should use a good magnifying glass and bright light to look for tale signs of the connection that is broken.
Jul 18, 2014 | Audio Technica Audio Players & Recorders
I have a atw-t52 audio techina wireless mic. And when i turn it on thr crackling begins to come through the speakers and i have to play with the input and output cable and move the base unit around and...
I have the same problem in my ATW T52, in st by its ok (the rf leds show perfect signal) but when i set in on the af level start punch and i hear in the monitor a noise like a heartbeat (pum-pum-pum....) Please any answer for this problem
German
Radio del Sol 96.3 Mhz
Villa de Merlo - San Luis
Argentina
May 20, 2010 | Audio Technica ATW-T52 Professional...
I have problem with channel on Audio Technica wireless microfon How can I change the channel because the same things wireless channel digital television and she considers the work of the microphone. Type...
I don't think is possible. But its entirely my point of view,as i feel technically its not possible.
Try checking your user manual provided for microphone. That may offer you better guidance.
Oct 10, 2017 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
ATW-T52, hissing/crackling.
A common problem that SOME have is due to the foam windscreen inside the metal screen rubbing the diaphram of the mic.
Unscfew the dome screen and make sure the foam is out agaist the scree everywhere.
If the dome has become dented, this is my cure: Temporarily remove the foam sheet inside the dome. Put the dome over the handle of a Crescent wrench (has about the right contour). Pound on the screen with a RUBBER mallet, rotating the screen as it reforms! Good as new! Replace the foam sheet and reassemble!
Dec 20, 2009 | Audio Technica ATW-T52 Professional...
I have a audio-technica ATW-T51 and need to replace the cable as it makes a lot of noise. Where can I go?
to a web site called parts express.com you will find anything in audio related items there..
Nov 23, 2009 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
How do I program the frequency of transmission on the mic?
Some of these have a body cover that just unscrews off, and expose a set of rotary channel and group selector that you can turn with a small flat screw driver. Match to the new numbers letters on the receiver. If it is the LED type you just need to hold the ch or grp button down until the display flashes then just toggle through the codes.
Jul 27, 2009 | Audio Technica ATW-T52 Professional...
Disasimbel freeway atw-t202 for repair
might just be the mic wires came loose...I have oner and the mic is held in by a small rubber O-Ring and as people drop it it falls out and can short out
Jan 11, 2009 | Audio Technica Audio-Technica 200 Series...
Change the frequency
hello firstable you need to know at how many ohms is the base unit then in microphone change the impedance transformer to match the low or high frecuency you want......saludos
Nov 20, 2008 | Audio Technica ATW-T52 Microphone
Vocals disappear in parts using this mic
It is very common to have the squelch on the receiver set at full or much too high. With the audio output unplugged or at least turned all the way down, and with the transmitter turned off, locate the squelch control - you may need a screwdriver depending on which model of receiver you have. Turn the squelch control counter-clockwise until the TX light turns on, then turn it back up just past the point where it turns back off.
If you turn it all the way down and the TX light doesn't come on, that's okay. If you get blasts of noise occasionally when the transmitter is turned off, then set the squelch a little (only a little) higher until it stops.
Joe
Jul 21, 2008 | Audio Technica ATW-T52 Professional...
Audio Technica ATW-T52 Professional Microphone Logo
378 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Michial Gueffroy
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
