I have an NC8430 computer. It has a new battery, and a new motherboard with windows 7 OS. The system recognizes the battery is or is not present, it indicates that it is charging the battery and that the battery percentage is 51%. Over a long period, weeks, the percentage will drop 2-3% this is on outlet power. The computer will not run on battery power, the charge will not go up. Is there a bios setting or some procedure I need to perform to get this computer to run on this battery? Thanks
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
Cindy Wells (An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Go to Control Panel, Administrative tools, Drive management, Right click on the connected drive and assign a drive letter. Make sure Windows sees this drive as "usable" if you loaded Win 7 NTFS and the XP OS used Fat32 Win 7 has had issues.
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB* ? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB) ? Dual-channel DDR2 memory architecture ? Support DDR2 800/667/533/400 DDR2 SDRAM Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS. For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Hi, To recognize more than 3GB of RAM you will need a 64 bit version of the operating system. If you install Windows 7 32 bit (normal for most users) you will only see 3. You should have both versions of Windows 7 (32bit and 64 bit) on your installation disk. However you will need a 64 bit capable processor to install it. Otherwise 3GB of RAM for a 32 bit operating system is more than enough.
make the dvd your 1st priority in bios for boot, if it cannot be recognized try taking the floppy cable out of the floppy drive, maybe you have a problem with your power supply
u better install windows 7 or updated os in ur system bcoz microsoft had stopped the updates for xp os. so i can say u to install latest updated os to rectify ur problem
