Question about Dishwashers
The water does not draing after the dishwasher is completed its cycle. Just sits on the bottom
    Habit-Forming:
  • 35 Answers
Some water in the bottom is normal but if it is inches deep and threatening to over flow you can disconect the power and remove the drain cover. Check for obstructions. If you do not find any obstructions the discharge valve may be sticking. If you open the lower front cover you can look and see if the lever is moving freely by turning the power back on and open and close the washer door. you will here a click when the relay engages and should be able to follow it to the lever.
Posted on Jul 29, 2008
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
Why won't complete wash cycle?
dishwasher is proballuy not draing due to bad water pump or restriction
Aug 01, 2014 | GE Dishwashers
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher repair
without model unablr to look up exact unit, but in genreral, either ther is a blockage/clog in oyour drain line not alowing complete drain of cycle, as far as never really washing, i would look into perhaps a faulty/ sloppy door switch assembly. if for some reason the dorr latch "loses contact" the machine will take that as someone openig the door and thus stopping from proceding in cycle.with complete model umber i may bbe able to assist further
Dec 30, 2008 | Dishwashers
The dishwasher in my kitchen doesn't seem to drain and it seems pump is not working
My motto is "if it ain't broke, don't fix it.", but in this case we will make an acception. Check the inside of the washer for a float device sitting on the bottom. Floats can get stuck or bent over, make sure it goes up and down freely
Jun 28, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not working
Hi Frazzledmum, Miele have a safety float switch in the bottom of the machine. (The float is a polystyrene disc). If the machine leaks for any reason, then the water sits in the bottom tray raises the float switch & all your dishwasher will do is activate the drain pump and flash those red lights at you. The reason is that somewhere under the machine there is a leak that needs to be investigated & repaired so in this instance I'm affraid that you will have to call a serviceman. Kind regards
Jul 22, 2007 | Miele 24 in. G638 Plus Free-standing...
Dishwashers Logo
Top Dishwashers Experts
