Question about Sony XM-2002GTR Car Audio Amplifier
Amp works but no sound from sub
Ive checked and double checked all my connections between the deck amp battery and sub. no wires are exposed. recently a speaker was shorting out on my chassis because the magnet in the speaker attached itself to the chassis so all speakers didnt work. i readjusted the speaker and secured it the 4 speakers worked fine but my sub didnt work, i tried using another sub but still didnt work, i also tried another headunit and still nothing. my amp is only about 7 months old and i'd had 2 have to purchase a new one if mine can be repaired. its a sub is a 1200 sony xlpod headunit and speakers are pioneer
  • 1 more comment
  • ellejay_21 Jan 03, 2009
    I have the same amp and I have two JVC subs I am trying to get working...No sound is coming from the subs and they are new out of the box. I got rid of my last subs because I thought they didnt work. The light is on inside the amp but no sound is coming from the subs.
    By the way..my stereo is a jenson....
  • Just1Garcia Feb 05, 2009
    I just bought a JVC KD-R200 my car has a voice navigation system and just about every single head unit states the navigation will work but the voice will not or atleast will not be heard. Is tehre anything in teh market that can correct this?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
Some older Pioneer radios require you to connect the Subwoofer RCA to the rear output on the back of the radio and then you have to turn on the subwoofer in the menu on the radio. What model Pioneer radio is it? Also, make sure that the RCA plugged into the amp is on the input side, not the output side.
Posted on Aug 10, 2008
My speakers do not work but my subs do.
Good day sir, hi, there reason why speakers don't work could either be the folowing:
  1. you speaker voice coil is burnt, to test, you need to get the door speakers out and locate the terminals, prepare a 1.5 double AA battery, use this to test you speaker. connect a wire from the negative of the battery to the negative of the speaker, and the positive battery to the positive terminal of the speaker with a series of gentle taps, you should hear clicking sound. if not replace the speaker.
a9b085b.gif Do it on the other door speaker.
2. check your speaker line from the amplifier to the door speaker.
3. check your power amplifier for loose and improper connection.
4. check your power amplifier itself. Thats it.
Its a little work, visit your local electronic repair shop if your speaker still won't work.
Oct 08, 2009 | Car Audio & Video
I have an Alpine MRD-M605 amp that recently has started having issues. My subs only produce sound when my deck is turned up full blast. The setup had been working for over a year with no problems. The subs...
If your deck is aftermarket; Does it have a dedicated Subwoofer output? if so, check the control in the deck (sub gain). If you are using a factory radio, and a high to low level adapter (speaker wires to RCA), it may be bad (not too uncommon) or check your fader front/rear any difference? Otherwise, you have one of two problems. A bad preamp in the deck or a bad pre amp in the amp. Both are fairly uncommon. More than likely it's a setting. Hope this helps
Jun 23, 2009 | Alpine MRD-M605 Car Audio Amplifier
Constant Power wire draining battery HELP!
Okay, I think I have it. The red and yellow wire into the deck need to be connected to two different power sources.
The red wire should only be hot when the accessory switch is on. The yellow wire is for constant power to maintain memory in the deck.
Connect the red wire to a source which is only hot when the ignition switch is in accessory position -- that should solve the problem.
May 06, 2009 | 1984 Lincoln Town Car
Sub not working
you need more power like gettin a bigger amp
May 03, 2009 | Kicker 05C104 Car Subwoofer
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
Sony xplod xm-554zr amp
if you are trying to run some highs with built in high-pass crossovers off of a amp that is setup for subs(amp is on low-pass) then your highs will not work. You are better off running another amp or running them off of your deck...
Aug 18, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Cdm alpine 7861
Make Sure the remote wire is connected from the radio to the amp, its normally a blue wire. Here is a picture of what the setup should look like.
Jul 27, 2007 | Alpine CDM-7861 CD Player
Sony XM-2002GTR Car Audio Amplifier Logo
668 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
