Question about Gestetner Copier
Gestetner 6002? How to enter sender name on scanner Gestetner 6002?
  • 37 Answers
You can down load a user manual for the machine at www.gestetner.co.za
Posted on Aug 14, 2008
Have a Gestetner Dsm520pf - it says scanner locked
First try unplugging the machine from the wall for 5 minutes and then plug it back in. If this doesn't work, you can try this: 1. Press Menu on the control panel until "Maintenance" appears on the top line of the display. 2. Press the scroll button until you see "Clear Memory" on the bottom line and press Enter. 3. Press the scroll button until you see the item you want to clear. I'd recommend the last option, Machine Setup, but be aware this may clear all settings out of the machine. 4. Press Enter. 5. Return to Standby Mode by pressing Clear/Stop.
Mar 02, 2011 | Gestetner DSm515pfd Digital Copier -...
Hi we have just installed a gestetner asm645 (i think thats its name), and want to delete the old companies accounts as when we try to scan something it says it needs a "senders" account to scan...
can delete user accounts under system settings. Press the button marked 123(where you get your meter reading). under system settings go to administrator tools and address book managments. can delete user accounts and create new 1's. Or you can trun the user authentcation off. Then no code is needed.
Sender - under system settings go to file transfer. input your smtp and managers account email. When programing user in address book look for add as sender and input the email address. When emailing you can select sender and destination. If the user is not set up as a sender the list will be empty and you would not be able to select a sender. set up a user (email) that any one can use.
Jan 21, 2011 | Gestetner Copier
Scanner Delivery server fails on my Gestetner dsc232
First, it doesn't work on Vista, if you have upgraded you OS??
So, have all of the destinations disappeared off the display?, and "updating destination list has failed' message displays" (or something similar).
If this is the case........ have you tried going into the "Scanrouter V2 admin utility", and under the "server" button select "set I/O device", then select "remove". If you are asked to "retain settings" select "no". Then click "add", then "Browse", it should find the machine, select "ok" then name it whatever you want -it's for identification only
This helps when (for some reason) the machine has become disasscociated with the Ip address for lack of a better description -particularily if the software is not installed on a machine with a statc IP.
OTHERWISE
Do the destinations still appear but the scans do not reach their destination even though they appear to be sent?
This happens when the Windows login password has been changed, because Scanrouter is linked to the admin password.
The way to tell is if you click to open the "Scanrouter V2 admin Utility", and get a message pertaining to a "wrong password" or similar. - Enter the NEW windows login password
OR
Has windows Firewall been enabled? TCP port #3670 needs to be opened
Please let me know if any of these solutions help, and Please rate me :)
Mar 19, 2009 | Gestetner DSc232sp Copier
Scan multiple pages to one file on gestetner 6002
I apologize but this is a little to tricky to explain here....
below are guides and information on how to set up and operate a Gestetner machine,
which will help you to sort out every thing..
This is the Gestetner Site to download manuals, user guides..
http://www.gestetnerusa.com/SupportDocumentation.html?OpenForm&zone=ZIDTDIE-54FRT7GE51&NavExpand=0
This is the Scanning Guide
http://www.gestetnerusa.com/manuals/savin/SavGestOpManuals.nsf/(All)/GX60027502ScannerReferenceScannerReference.html/$file/Scanner%20Reference.pdf
Oct 27, 2008 | Gestetner Copier
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Scanning - error: Sender's name not selected
Finally figured this out!!
Go to: UserTools - System Settings - File Transfer Tab - page 3 of 3 - Auto-Specify Sender Name - <ON>
Jan 30, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Dsm618 scanner
You must register as sender in the address book.
Aug 11, 2007 | Gestetner DSm618 All-In-One Printer
264 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
