Hello to everybody,
I own a Nikon FM2n manual focus camera, and I just got a used Vivitar
Flash 283. The serial number of the flash is 4221384 and it says "Made
in Japan" at the bottom.
I would like to know if somebody around has any experience about this
combination and if it is safe to use toghether. I heard that the older
Vivitar 283 could damage my camera....and I don't want to.
Thanks in advance,
Mauro
Rating: 0%, 0 votes
It's the beauty of FM2n
....maybe if you flash it too much to you mother in law...
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
contribute to this NG. Kudos for the reply.
Sent via Deja.com http://www.deja.com/
Before you buy.
Rating: 0%, 0 votes
would assume that there is no problem. I've got 2 FM2n's and 3 283's and have
had no problem with them at all. I use Quantum Turbo batteries with the flash.
Great set up. Not all the bells and whistles of the newer electronic equipment,
but it works if you know what your doing. And I'll take it places that I
wouldn't take some of the newer equipment.
Dave Nelson
In article <39C8FE2C.81DAE @nhlbi.nih.gov>, panig @nhlbi.nih.gov says...
Rating: 0%, 0 votes
chips and circuit boards. The Fm2n has nothing to damage.
Rating: 0%, 0 votes
<sco @educ.umass.edu> writes
The only reliable way to check the trigger voltage is with a digital
volt meter across the hotshoe (from the centre pin on the base and
either of the contacts on the side of the shoe) as the gun charges. You
can actually see the voltage rise as the gun charges.
I have two similar 283s with nothing that tells them apart, one reaches
about 270v, the other 11v whilst charging. Guns bought new in the last
few years should be OK.
Whilst I's be very wary about using a high voltage gun on a new
electronic camera, I'd expect the FM2n to be able to cope with it (not a
guarantee though).
John
Preston, Lancs, UK.
Rating: 0%, 0 votes
No problem at all with the FM2. If you ever add a newer camera to your
collection though, you should make sure the flash is not the older, high
voltage model.
Rating: 0%, 0 votes
I read that the triggering voltage (between the centre pin of the flash and
the contacts of the camera) on the flash should be less than 10 volts to
prevent damage to the camera. I have also read that this flash has a
triggering voltage of 250 volts!!
I tried to call Vivitar customer service but I couldn't reach an operator.
I have already used it on my camera and it works fine... I was just curious
for the future.
Thanks,
Mauro
