Question about Dell Inspiron E1505 Notebook
Connecting laptop to lcd tv
My laptop has a vga output for an external moniter, but it also has an s-video plug. Which cable would be best to use for the best picture quality?
    Genius:
  • 2,028 Answers
Always VGA, however, if your tv doesn't have a VGA port, then it may not be compatible. When using a tv for a monitor there are a few things to keep in mind. First tv's are made to be tv's, not computer monitors. With most you won't get the visual resolution that is expected, and with some you need drivers in order to get the resolution or to get it to work at all. Hope this helps, and good luck.
Posted on Jul 29, 2008
Fn f1 diidnt do it, hdoes any one no if i can fix it wihout having to replave moniter or connection switch?
I think you are hitting the wrong Function Key combinations. Why are you using an external monitor anyway? What is wrong with the laptop's LCD Screen?
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
Each time you press the FN key plus the correct Function Key it toggles the Display between three stages (Show on Laptop only, Show on External Monitor Only, Show on both the laptop and the external monitor).
Apr 09, 2012 | Computers & Internet
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
What is needed to connect a laptop to my Vizio 42" LCD TV
What type of laptop (make/model) do you have? What video outputs are on the unit.
For most laptops, you need a VGA cable (assuming your laptop has a VGA port); the cable is sometimes labeled as a 15 pin D-Sub cable. If you want to use the TV speakers, you will also need a stereo 3.5 mm audio patch cable (male/male) . With both the TV and the laptop off, connect the VGA cable between the computer and the TV and put the patch cable from the audio out of the computer (speaker or headphone jack) to the VGA audio in on the TV. (The label is RGB PC for both jacks.) Then turn on the TV and then the laptop. (With some laptops, you may need to access the BIOS and enable the external video port. This is done by pressing the appropriate key repeatedly as soon as you start the computer. The key is Esc, F1, F2 or F10 depending on the brand of laptop.) Some laptops will automatically send the signal to an external monitor when it is present. On most though, you will need to set the display to the external monitor. This depends on the OS. Some laptops have a function key that does this. In Windows 7, you can do this by right clicking on the desktop (a spot with no icons or running programs) and choosing Graphics Properties. Then set how you want the display to run (external only, both screens or the laptop screen only). Please note that you may need to adjust the resolution for your graphics system. The best choices are 1920 x 1080 or 1360 x 768 at 60 Hz, depending on the laptop.
The GV42L does not correctly interpret an HDMI signal from a computer so do not use the HDMI port if your laptop has one. Also do not use a VGA to component video cable. If you have a laptop without a VGA port, you will need the correct adapter (DVI to VGA, for example).
I hope this helps.
Apr 14, 2011 | Vizio GV42L 42 in. LCD Television
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
No VGA signal from my Lenovo laptop to the tv
Most notebook computers can be "toggled":
* video-output only to LCD screen
* video-output only to external VGA
* video-output to both device
Be sure that you toggle to select the 2nd or 3rd of the above settings.
Apr 03, 2010 | Olevia LT27HVX 27 in. LCD Television
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Feb 10, 2009 | Sony VAIO A250 Notebook
Connecting Laptop to LCD
the following connections available to connect ur computer to an TV:
S-Video output: If you have video card(external u will have this), you require an s-video cable and you connect s-video out of your computer to the s-video int of our TV.
TV-OUT: if you have video card(external u wil have this) you you require an coxial cable and you have to connect TV-out of your computer to TV-IN of our TV(it is place where cable connection goes from your cable operator)
DVI-D: if you have video card(external u will have this) you require an DVI-D cable you haveto connect DVI-D out of your computer(a white 15-pin port which looks like VGA port) ....
VGA: it is the port on your computer which is only used to connect to your computer but not to your TV or LCD(strictly)
Thanking you,
M. Sridhar
Dec 29, 2008 | Gateway GM5442 PC Desktop
Philips 42PF9946 connect with laptop
Connect to the VGA port on the laptop, using a standard video cable.
Here is how VGA port looks like on your TV:
Note on some laptop you need to activate external video output by pressing a combination of keys, this will swap between laptop LCD video and external video.
Sep 13, 2008 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
LCD TV and VGA output
The resolution and refresh rates have to match exactly to the TV for it to work correctly with the computer.
The newer computers are using much faster refresh rates by default. Their default resolution is also different.
Consult the manual for the TV and see if the computer's external monitor output can be set to match to what the TV exactly requires. Both the refresh rate and resolution are critical.
Jerry G.
Apr 20, 2008 | Televison & Video
Compaq nx6110
Usually one of the function buttons F5-F8 etc together with the FN button will toggle through from lcd to tv/external monitor to both.
Is the cable S-Video or does your tv accept a dvi or vga input?
Do you connect using the s-video output on the laptop or the standard external monitor port?
Mar 21, 2008 | HP Compaq nx6110 PC Laptop
Dell Inspiron E1505 Notebook Logo
69 people viewed this question
Alun Cox
