Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Heats intermittently
My dryer seems to be heating intermittently. The lint trap and ducting are completly clear with no obstructions. During a sensor dry it stuck at 20 minutes and stayed there running with no heat. I removed the sensor and cleaned it up and put it back in and the dryer worked for that load, but failed for the next. I repeated and it worked.
  • Donna Frank Sep 09, 2008
    We had a power outage also from the hurricane Gustav. Our dryer runs but it is not heating. It did work for about 4 loads after the power was restored but then quit heating! Help!
We had a technician come out to look at the dryer and it was a burned up wire leading to the timer. He replaced the timer....ouch....and all is good. We decided if anything else goes wrong with this washer and dryer...we are buying a new set!
Posted on Sep 17, 2008
My dryer has been blowing the circuit breaker every now and then and I am wondering what the problem could be.
  • 164 Answers
The herating element might be going bad. disconnect power, remove and inspect the heating element. look to see if its getting thin at any point. as it heats it could be seperatring and only give heat when it cools completely
Posted on Sep 05, 2008
My dryer takes forever to dary and the lint and the clothes feel damp. I can only dry 1/2 a load at a time. Whart's wrong?
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Also, make sure the duct is not kinked. Also, your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Dec 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer heats up but close remain wet
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open the lint trap to clean it out? Dirt has fallen down inside the dryer.
The panel must be removed
Try a swifter cloth on a steel rod to obtain catching it
Swifters really work well on lint that is stuck inside these vent tubes or duct work
Jun 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer heats randomly..Igniter is working.
Generally operation when cold that worsens with use indicates a component that is failing when hot. Start at the burner with the coils and work your way back to relays on the control. Sounds a lot like a bad coil on the burner. I have seen these do 2 complete loads then fail. Setting over night and cooling off will work again the same way. Intermittent conditions are a real challenge sometimes.
Eric
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
WILL NOT DRY
Check that the dryer duct at the back where it connects the dryer to the wall has not collapsed to restrict air movement to the house vent duct.
Check that the vent duct all the way to the outside of the house is not fully or partially restricted in any way.
Make sure the lint screen is clean.
Make sure there is no buildup of lint inside the dryer where the heat enter the drum.
You should be able to walk outside with the dryer running, and feel a blast of air exiting the dryer vent. If not, find the restriction.
A dryer warming up, and then shutting down is normally a sign of a restricted vent duct at some point in the system. Particularly if nothing is done, and the dryer heats up momentarily when the cycle is tried again.
Reply back your findings for further instruction or information.
Jan 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune Model #MDG6800Aww
Hi!! You seem to have a problem with your heating element on the dryer..Also make sure that your breaker going into your dryer is on..Good luck..
Jan 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
191 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
