Question about Maytag Washing Machines
Maytag Neptune stack washer/dryer model#MLE2000AZW. Water will not pump out of tub at end of cycle. No kinks in drain line. Is there a fuse on the unit itself?
This is what I did and it worked. Remove the fabric softner blue pouch from the washing machine. Pour a small quantity of draino in the fabric softner resevoir. Wait until the draino drains. Pour hot water in the resevoir area to ensure that the hot water flows freely. This should take care of the problem.
Posted on Oct 08, 2012
Maytag model MLE2000AZW fabric softener overfills and leaks out of the door???
Posted on Jun 03, 2010
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I need an operating manual
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's and installation manuals are available in .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Apr 20, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Water will not drain from the washer after I run a load. I've run it a few times now to see if it will drain and it just stays stagnant. Help!!!!
check the tub to pump to drain for a blockage or kinked lines and the pump for lint,coins,etc. as a blockage will be sensed and pump wont start to drain the machine even in a static drain w/o the spin cycle
Mar 19, 2010 | Frigidaire FEX831CS Top Load Stacked...
Maytag Neptune Superstack water accumulation and odor
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!%5
Jan 27, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
My maytag will not spin on spin cycle. water empties out OK but just won't spin? Muzza
it may have a build up ol lint. under tub or in the drain out let this would leave water under tub / as it floats. and if it cannot drain comlpetly ( no spin also ck for a kink in drain . or a bad pump . hope this helps ..
Dec 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Water won't completely drain from tub. Door seal is very moldy.
Had a simular problem. In my unit the water was not visible in the drum but you could hear it when you turned the drum by hand.  The answer as told to me by the Maytag repair man:  The machine is designed to hold the water after the cycle is complete.  As he was replacing the boot seal he suggested to just leave the door open so the seal will dry out and not mold.  This has been working for the past several years.  No mold has appeared on the new boot seal.
From another source I read that the water is left in the machine for balance.
Feb 02, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Washing Machines Logo
609 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
