Question about Sewing Machines
Blindstitcher adjustments I purchased thisblindstitching machine several years ago, but just today had the courage to tryit. I managed to thread it successfully,and when I tried sewing, it sewed the top (folded) part of the hem, but theneedle did not catch the bottom fabric. Can you tell me what I need to adjustso that it will catch? And in which direction. The instruction manual is not atall clear about troubleshooting and the drawings don't even match the machine; do you know of other documentation that mighthelp me? Thanks. I really do need your support. Kathy
    Problem Solver:
  • 6 Answers
In addition to the bite adjustment knob, you might try changing the needle. Once you change to a sharp needle, you may find the bite adjustment can be reduced.
Posted on Aug 14, 2010
  • 323 Answers
There should be a knob on the right front of your machine which can adjust the depth of the stitch. Usually it gets deeper when you turn it to the left nut that's not that important. Turn the knob a couple of numbers and see if it gets deeper or shallower.If it gets deeper, turn the knob a couple more numbers and check it again.If it gets shallower, you are turning it the wrong way. Turn it back and start over. Keep doing this until it looks the way you want it to.
There is also another knob or lever that says 2:1 and 1:1
2:1 will skip the fabric every other stitch which is great for thinner fabrics. 1:1 catches every time.
Don't be afraid of this machine. It's just a little different and you won't kill it with a simple mistake.
sewman7
Posted on Jul 30, 2008
I have a very old baby blind stitch hammer that use curved needles. The old pkg of needles says LWx6t, 29-49, 2 1/2/65.
LWx6T and 29-49 indicate the same needles. The 2 1/2 65 is probably the thickness of the needle. To match this needle, purchase: https://www.amazon.com/Organ-LWX6T-LWX2T-Industrial-Blindstitch/dp/B00642IOF6 . However, you may need a different needle (like the 3, 3 1/2 or 2) depending on the thread/fabric that you are using. A few other sizes of these needles are here: http://www.sewingsupplywarehouse.com/lwx6t.html . You always want to choose a needle that isn't too large or too small for your thread. With standard sewing machine needles, you use the slot in the needle above the eye of the needle to check that the needle is the correct one for that thread. (The slot should be just slightly wider than the thread.)
I hope this helps.
Jul 20, 2017 | Sewing Machines
How to do blindstitch hem with a pfaff 1035. I have the blind stitch foot
You need to also have a blindstitch stitch on your machine. It looks something like this:
-------V--------V--------V-------
The straight stitch segment is stitched on the hem fabric, but the V portion zags over and catches a couple threads in the fold on the wrong side of the garment fabric.
Blind Hem Stitch with sewing machine Make It and Love It
Feb 22, 2017 | PfaFF Sewing Machines
I purchased this Singer only days ago, today is my first use.Although my machine worked earlier, now my bobbin isn't feeding properly and Is not stitching.
Install a brand new needle.
Remove all the thread from the machine and rethread from the beginning. Be sure to ALWAYS raise the presser foot when threading the upper thread so the thread will seat in the tension disk. Verify that the thread path is correct and that the bobbin case is threaded correctly. Check the upper tension setting--normally, it would work best around the midway point.
If there are still issues, you may have a defective machine.
Feb 09, 2017 | Singer Sewing Machines
How to adjust timing for Rex blindstitch hemmer
As long as your machine is not skipping stitches the timing should be fine. Three things to check: take your thread tension assembly apart so you can remove the discs and clean. Debris often gets between them and causes irregular tension. Next check the point of the looper to see if has a burr. If so take 600 sandpaper or crocus cloth and remove. Last-Check the upright pin that the looper passes--it too may have a burr.
Mar 24, 2015 | Rex RX-518
How do you adjust timing on Rex commercial blind stitch?
I was just researching the same issue, only for my Lewis Blindstitch. I found a copy of the US Blindstitch maintenance manual on the mansew.com webstite. It looks like the setup is very similar to my machine, so maybe you can adapt the information to yours also. Good luck. Sorry, I was not able to post the hotlink, but this is it spelled out, exactly as it shows.
http://www.mansew.com/US BLIND/USBlindstitch_Maintenance.pdf
Apr 30, 2009 | Rex RX-518
What type thread do I use for a blindstitch machine?
The short answer is: You can use any type of thread that is suitable for the garment. Regular sewing thread, serger thread, etc.
Longer answer: Some like to use monofilament thread because it is clear and goes with any color, but it is hard on the machine and can actually wear grooves in the thread guides.
I really like to use Gutermann Hemshire U151. It is a fine polyester thread that is very flexible and works great in a blindstitch. I order it from Atlanta Thread and Supply (www.atlantathread.com). Their prices are reasonable and they ship quickly.
Mar 12, 2009 | Rex RX-518
Top tread bird nesting.
When you say top thread nesting, I supose you mean that the thread is messed up at the top of the needle plate.
If so,
1st, either your bobbin thread is completely loose, or the bobbin thread is not held under the bobbin case spring,
or lint has been accumulated under the bobbin case spring.
2nd, the top thread is very tight,
or both.
Jun 10, 2008 | Janome Sewing Machines
Singer 4572 model: thread breaking, skipping stitches
I have this same machine and it does this sometimes, too. I've found it's usually due to a couple of things: 1. The thread is caught on the spool in the little **** that holds the initial starter piece. If you turn the spool around with the **** on the side away from the bobbin maker, that usually does it. 2. The needle is not in with the thread going from front to back (it may be in with the thread going from side to side). 3. The thread is bad. (I had one spool that actually had "lumps" in it!
Hope this helps - good luck.
Aug 13, 2007 | Singer 5062 Mechanical Sewing Machine
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
