Question about Frigidaire FTF530FS Front Load Washer
Beko washer i have a beko washer model wma510w and it will wash but not spin
    Scholar:
  • 123 Answers
Hi there.....this problem can occur with the W510 if you have selected the 30minute wash and loaded a full wash load....the 30min wash is to be used with a 2.5 kilo load only.....if the problem is occuring in other selected programs then you can check (a) is the machine draining...if not check filter and pump..(b) check the motor plug that it is secure....remove it refit and test.....check the carbon brushes in the motor....and lastly if al the above are ok then you got a faulty PCB Board.
regards Sir Galahad
Posted on Aug 23, 2009
  • Jim Gallagher Sep 03, 2009
    hi there ,,,,,this problem is usually related to a faulty Main pcb board...located behind the front panel of the machine......however it is also possible that incorrect use of the appliance will cause a similar problem...this model has a thirty min wash facility..however this wash must not exceed 2.5 kilo...failure to observe this limitation will result in a no spin scenerio....Beko generally replace the motor along with the pcb board...as its usually the motor that causes the board failure..check cost of parts etc...this model was quite inexpensive and may not be worthwhile repairing
    regards Sir Galahad
  • Jim Gallagher Sep 21, 2009
    hi there......failure of this model to spin is usually attributed to either (a) faulty Motor...(b) failed PCB board....check as follows...(a) tilt appliance back from from front to rear tilt enough to allow you access to the motor underneath....(support the apliance to prevent it toppling over on you)...gently but firmly tap the frame of the motor with a light hammer or suitable object...lower machine back to normal position..load machine.select rinse..if machine spins erfectly this indicates sticking or worn motor brushes...failure to spin indicates PCB Board failure (main control board)
    however ive seen cases where both items had to be replaced..check out cost first as these machines are not expensive to purchase new
    regards Sir Galahad
My washer wont spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor more Beko WME7247W test videos at site
Aug 08, 2014 | Beko WME7247W Washing Machine
Why wont it spin fast
Hi if your Beko washing machine has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
Washer will not spin, it makes noise as if bearings have gone, empties ok and washes ok
Hi if your beko washing machine is causing a problem and wont drain or has a spin problem then you have to check the carbon brushes first.
May 03, 2014 | Beko Washing Machines
Hi can you tell me how to change the brushes on my beko washing machine please? Its a Beko WMA510W, thanks
If the motor in queston is a C.E.Set or Sole, you can do it by tilting the machine back against the wall. Otherwise, you'll have to take the back off and remove the motor by opening the bolts. Easy to change the brushes after that
Dec 08, 2009 | Washing Machines
I had to have my washing machine repaired in Feb 09 , it wasn't a year old untill June 09 it has now broken down again where do l stand . It is a BEKO WMA510W
Even though the washer was repaired under the warrenty, now that it is more than a year old, any repair req'd will be chargeable, this is the case with all manufactures, unless you took out an extended warrenty.
Please rate my solution.
Thanks.
Oct 30, 2009 | Washing Machines
I need a copy of the instruction manual for Beko Washing Machine WMA510W
Head over tho the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2009 | Washing Machines
Beko wma510w only spins when it feels like it
I have the same model and problem. I suspect the problem is due to the machines sensor which detects when it is off balance. The problem is most likely to occur when doing something like a single large towel. You can see it thinking about spinning but as soon as the drum starts to wobble it slows back down again.
Any ideas on how to stop this happening (sensor replacement) would be useful.
Jun 21, 2009 | Washing Machines
Need manual for beko wma510w
hi instruction books for many appliances can be ordered from sales@gwhitedist.co.uk
May 12, 2008 | Washing Machines
WMA510W
Click on "washing machines" (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site!
Jan 06, 2008 | Washing Machines
Frigidaire FTF530FS Front Load Washer Logo
187 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
