Question about Raymarine C80 GPS Receiver
Broken pin I have a Raymarine C80 with a broken pin on the DSM port. Can I buy the whole power assembly (PSU) with all new ports? P/N 136789 or 4566-D05 or 3015-310 one of these is it. I have it open and see three different numbers.
5 Suggested Answers
  • 43 Answers
SOURCE: Scanner not reponding - Checking HW
1.try with a new software 4.29
if you have an old one like 2.14 you have a problem.
2. After this try you C 80 on a nother boat or Raymarine dealer
than you will know if the C 80 works
Posted on Oct 13, 2009
  • 43 Answers
SOURCE: GPS antenna
If your old antena is a Seatalk or NMEA antena you can use it for your C80
If you GPS antenna is older than five year change it.
Posted on Oct 31, 2009
  • 111 Answers
SOURCE: RAYMARINE C80 SEATALK CABLE INSTALLATION
The Raymarine RS125 has five wires and can be either seatalk or nmea. It would be best to get a dealer involved. If things are hooked up wrong you'll fry your equipment.
Posted on Jan 22, 2010
SOURCE: My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Posted on Apr 28, 2010
Testimonial: "Factory reset solved the problem. Soft key next to power button worked a treat!"
Can't update software
Hi
As you have isssues with boyh software update and chart I would put my bet on the cartridge reader, it could be a loos or broken pin. Use a penlight or good light and inspect the pins in the reader for damages and check that there is no pin stuck in the Navionics cartridge. If no pin is missing it may just be loose, can be fixed by opening the plotter inspect the reader from behind and use a glue gun to resecure the pin(s). In worst case you will have to replcae the reader (affordable).
Apr 02, 2014 | Raymarine C80 GPS Receiver
I have a Raymarine C80 shart plotter / sounder with a DSM 300. I can't get the "status" light to come on and therefore I can't do a DSM reset. The fuse on the power input to the DSM was blown so I changed...
I would think it's prity much certain that the DSM 300 is duff. I returned mine back to Raymarine for test and repair £200 + VAT They came back unable to repair as they have no parts for the DSM 300 . They undertake to be able to repair units for up to 10 years and I think that's why they offered me a DSM 30 that will work with my analog display in my case a C70 MFDU and the existing transducer. OR an upgrade to a CP370 digital sonar unit, this will work on your existing tranducer but you will have to upgrade your display to a digital unit, I went for the upgrade and purchased an "a"series 9" MFDU with a chart, fantastic performance. This has left me with a spare analog MFDU that will hopefully keep my radar running a little longer before I have to go down that road and upgrade.
Hope this helps
PS there was no extra to pay so a CP370 for £240 was a good deal
Oct 17, 2017 | Raymarine C120 System Pack C120 Raystar...
What is the connection path from Garmin 72 to raymarine c80, using NMEA 1083
I'm taking this as you want to send the gps information to your C80 not receive from the C80? If this is the case the brown wire on the garmin is the nmea data out +. The Black wire is considered nmea out neg (-) of the garmin. So hook the garmin brown to the white on the raymarine. Hook the black from the garmin to the green on the raymarine. That means you are outputting lat/long info to the raymarine from the garmin.
Jan 14, 2012 | Raymarine C80 GPS Receiver
Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
Oct 03, 2009 | Raymarine Boating
DSM Port on RayMarine C80
The only other way would be to change the PSU board in the unit. The connector back plane is connected to this board.I am a authorized Raymarine repairer. I could drop ship you the board from Raymarine and email you an instruction manual on how to change it.I am not located in the US so shipping the unit to me for repair becomes expensive.You can also check with your dealer in Seattle first but I do not think that he can buy the board from Raymarine. Raymarine policy on repairing product is different from country to country. We are on the other side of the world so Raymarine allows us to repair there product as it is to costly to ship it all back to there repair facility in the states or the UK.If your unit is still under factory warranty then if you open it it will void the warranty.So then you would have to send it to Raymarine. With a diagram if you are natural a technical person you will not have a problem changing the board.If you are technically challenged I would say send it to Raymarine. Hope this helps.
Aug 28, 2008 | Raymarine C80 GPS Receiver
Scanner self test result...is display comms/fail /raymarine c80 18" dome
Chances are that your scanner cable may be bad. Check inside the dome and make sure that the little wires going into the black connector from the radar cable are seated correctly and all the way in. This can cause tons of problems. Also check to make sure that your pins in the back of you unit are not corroded or broken off.
Jul 24, 2008 | Raymarine C80 GPS Receiver
Broken power connect plug
The pin assembly is available online and usually runs between $10-$20. A quick Google should find you multiple sources for the part. It's not a hard job to do, just be careful when you are soldering the new assembly to the motherboard. And get a decent cable retention device after you fix your system, that way you won;t have that problem again.
This is what I use and recommend.
Apr 17, 2008 | Acer Aspire 3680 Laptop
Raymarine C120
I don't have the sounder so can't address your question directly, but you can download all Raymarine manuals for your gear directly at www.raymarine.com
Aug 23, 2007 | Raymarine E120 GPS Receiver
Fish finder
You have either the DSM250 or DSM300 digital depth sounder module installed. The C80 is not seeing it.
There is an LED status light on the DSM. For starters, it should be lit either red, yellow or green to confirm it is actually powered on. We are hoping for a green light.
Double-check the cable between DSM and C80 for tightness. Also double-check the DSM's power cable for tightness.
The DSM's are sensitive to voltage level onboard. Make sure the DSM's connections to the circuit breaker panel or battery are tight and clean. Double check with a multimeter the there is 12V DC available to the DSM.
Let me know what you find.
Jun 18, 2007 | Raymarine C80 GPS Receiver
Raymarine C80 GPS Receiver Logo
161 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
