Question about Maytag Neptune MDE5500AY Electric Dryer
Wiring a 3 prong neptune to a 4 prong new outlet
I have a maytag neptune-dont have model number in front of me, but I think the dryer is around 3-4 yrs old. It has a 3 prong cord on it, and my new place has a 4 prong receptacle. I already wired it the way my electrician told me, and I have now blown the circuit board, and have to buy a new one. What is the correct way to wire the new cord on. Thanks
norman
  • 1 more comment
  • shaneqjn Aug 28, 2008
    I have a 3 prung dryer and a 4 prung outlet. How do I change the wire to the 4 prung? I already brought the 4 prung wire. "please help me"
  • tlanepaint Aug 31, 2008
    how do you wire a 4 prong to the MDE5500 ayw dryer
  • pamelasorg Dec 08, 2008
    What if there's already a green wire attached from inside the washer? Do I connect the green wire from my 4 prong on top of that other green wire? Mine is an older Whirlpool dryer.
    Genius:
  • 1,028 Answers
Red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Posted on Jul 30, 2008
How to ground a MDE6700AYW dryer after changing to a 3 prong cord
Hi fievelsgal21...
Go to the following webpage and it will show you what and where to connect the ground wire when converting from 3 to 4 wire or 4 to 3 wire.
Please rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 28, 2012 | Maytag Neptune MDE6700A Electric Dryer
Maytag neptune endeavor 3 prong electrical cord conversion
Yes this can be done but this is removing the ground wire in the plug which if you have a thunderstorm and a purge comes threw it may blow the board now this is a maybe so it will have to be hooked up L1Black L2 red And white. on the back of the dryer instead of L1 L2 Common and ground. They have operated this way for 20 years. Please rate my solution and leave testimonial it is how i earn my achievements thanks in advance.
Apr 23, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Changing a 3 prong plug to a 4 prong for my Maytage Neptune Dryer, MDE6800AYW
Hi rbarnabei...
Go to this webpage and you will see how to wire your dryer from a 3 prong to a 4 prong plug.
Please take time to rate me
Jul 11, 2011 | Dryers
Where can i get the wiring diagram for the neptune dryer model #mde4000ayw so i can put the 4 prong cord on the back?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Oct 14, 2010 | Maytag Neptune MDE4000 Electric Dryer
Changing 3 prong to 4 prong outlet
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My power cord does not fit the electrical outlet in my new apartment _ maytag Neptune electric dryer. Is there an adapter to change the cord from 3 prong to 4 prong
You need to go to a local hardware store and buy a new cord. There is an adapter but it is more exspensive than the cord and I have seen problems with them overheating because of the fine dust getting in them. Your cord is easy to replace there is a access panel that is held on by a screw where the cord goes into the machine. You will need to remove the screws holding the electric wires there will be 3 on your dryer. The 4 wire cord has an extra ground. You can put this under the screw that holds the access panel on. The two outside wire connectors on your dryer are the hot wires each carries 110v the center wire is the neutral wire and also acts as a ground on a 3 wire dryer. The 4th wire is an ground for house trailers and some areas require them as a seperate ground from the neutral. I hope this helps
Aug 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Dec 24, 2008 | Maytag Neptune MDE4000 Electric Dryer
My dryer has a 3 pronged connector but the new house has a 4 pronged receptical. I took the old cord off and purchased an new 4 pronged cord. My problem is that the dryer has three connecting points for...
to a screw on the rear of cabinet there may already be a wire connected there if so remove it and tape it off install green ground wire there
Aug 05, 2008 | Dryers
Switching the cord on maytag neptune dryer
dre, sounds like you moved and the dryer electrical outlet is only 3 pronged, This tells me that the dryer will be grounded through the neutral leg. Just hook up the cord and you should be fine. Make sure the white is in the center. Catriver.
Dec 07, 2007 | Maytag Neptune MDE6700A Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
460 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
