Question about Rimage AUTOMATED PRINTERS: PrismPlus AutoPrinter
Printing issue The arm of our printer does not sit the cd correctly which does not allow the little plate to move in to be printed.It may print one and then after that we have to adjust the cd and the it will allow it to pull in to be printed.
    Problem Solver:
  • 30 Answers
Simply adjust hhow the printer rests on the autoloader. There are two little allen wrench slots which adjust the printer both horizontally and vertically.
www.techwaredist.com
Posted on Nov 14, 2008
The printer not printing in the correct area of the paper, how i can adjust the printing area?
Check the printing options in the computer. I'd say there is an option that was checked thay you don't want. There should be a PDF owners manual that came with the software Cd. Check that too.
Mar 18, 2015 | Epson Lq-690 24 Pin Dot Matrix Printer
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
My brother mfc 240 c is keep saying paper jam but we have move the cover and we do not see a paper jam how do we resolve this issue please help
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum. get more information to fix brother mfc printer paper jam problem .
Jan 24, 2011 | Brother Multi-Function Center MFC-240C...
Pixma MP610 will not start up. Was working OK. Just under 1 year old. Printer detected by computer, and print carriage lifts, but will not move. Ink in all the cartridges Front lights blinking alternately...
6A00 indicates a problem with the carriage lifting mechanism. Simply put there is beam kind of thing that the cartridge carriage assembly on which the print head rides on and something on it is obstructing the carriage assembly. The fix? Open the printhead cover and turn on the printer. You will see that the carriage arm is extended and tries to move back to the initial printing position but it can't. Just give it a little helping hand and bingo! The print head moves to the correct position. You will then have to clean up whatever is blocking its path. Usual culprits being ink, paperclips, tiny bits of popcorn(or anything else you prefer eating while printing!:)
Let me know if you need more help,
Sai.
Jan 03, 2010 | Canon Office Equipment & Supplies
Brother SX 4000 stopped printing. Ribbon is
Remove and inspect the ribbon cartrige, wind the knob and make sure that the ribbon moves and reinstall. Check that the correction tape is installed properly. Check that the ribbon plate assembly is not in the correction position. Try CODE RESET (Q key)
Dec 22, 2009 | Brother Office Equipment & Supplies
Printer not printing text
When printing a web page which has only 5 lines of text, the printer prints the 5 lines and scrolls the page empty. But, I wanted the printer to stop printing after it has printed the available 5 lines. Also, it should not print the header and footer automatically.
Dec 04, 2009 | HP DeskJet 3740 InkJet Printer
Paper jam error in the output does not allow printing
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Epson R-260 offset
Make sure you are using the correct version of the Print CD. If you had a older Epson printer with this program remove it, and install the one that is on the disk.
If you are operating on a Mac and it has automatically updated to the latest OS, remove and reinstall the program.
Aug 22, 2008 | Epson Stylus Photo R260 InkJet Printer
BROTHER MFC 240C DEFAULT TO FAX PRINTING
We moved from 561 to 772 area code. Now we can not receive faxes. What do I need to do?
Did not have an issue receiving faxes at the old area code: 561
please email with resolution:
purplegem0713@gmail.com
Thank You....
Aug 10, 2008 | Brother Multi-Function Center MFC-240C...
Cd tray not feeding
I had the same problem. My printer was sitting too far back in the cabinet and the cd tray was hitting the back wall when it was pulling it throuh. I moved the printer forward and the obstruction in the back was no longer an issue. It started printing all cd's just fine.
Jul 17, 2007 | Epson Stylus Photo R220 InkJet Printer
Rimage AUTOMATED PRINTERS: PrismPlus AutoPrinter Logo
104 people viewed this question
Top Rimage Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
