Question about Roper RAS8445KQ Top Load Washer
Tub off balance
The tub on my washing machine is off balance. How do I get the lid open?
  • brian23707 Oct 04, 2008
    washer has been leveled but yet the tub tilts toward the rear of the machine. I checked but found no apparent missing parts. I noticed only one spring that could hold the tub level in the rear of the machine on the opposite side, itoo is in the rear of of the machine. The washer is a roper model top loading type purchased last year.
  • 370 Answers
Pick up the back of the machine a few inches then drop it. It has self leveling legs it will level everything and it should work fine after that.
Posted on Nov 18, 2008
Kenmore washer lid locks tub moves for about 3 second
Have you tried balancing the load? Your washer is either sensing the load is off balance or displaying the effects of a tub problem. So step one is balance the load. Let me know if that doesn't help.
Jan 18, 2013 | Washing Machines
Off balance .... open the lid and the washing cylinder sits forward... it spins but clunks even while empty and on gentle... had the drive belt replace less then two years ago... ideas? tried to balance...
Check the suspension springs that hold the tub. Here is a link to the springs in case you need them. Here is a video to show you how to access the springs.
Jan 02, 2011 | Kenmore 23822 Top Load Washer
Is off balance during the spin cycle mor often
I have a 10yr old Maytag Atlantis model MAV7258AWW. Here is how I solved my balance problem. It appeared that I had two problems. One was that it would not spin fast, the second was that it would spin off balance. To get the washer to spin fast like it should I had to open the lid then close it, re-engaging the spin cycle. I opened the top and watched the motor engage in the spin cycle. with the top open, I would open and close the lid activating the lid switch. Each time I closed the lid I noticed that the motor would move a little bit more on its glides to tighten the belt. Sort of like a automatic adjuster. The motor is designed to pivot one way for the agitator the other way for spin. If the motor does not pivot correctly, the belt will not tighten and will slip. I removed the front panel, cleaned and lubed the pivot area. Now the motor glides on the pivots like it should. I ran the spin cycle and the motor slid all the way to one side like it should, the belt tightens and the spin cycle spins. Now that the spin cycle works, quess what?? The balance problem is fixed as well. It appears that the reason that the tub was going off balance was because the belt was slipping not spinning the tub at maxium speed as designed causing the off balance problem. The tub was not spinning fast enough causing the off balance problem. I have ran several loades in the washer and not a problem. I did replace the snubber, it was worn out but it still spun off balance. I hope this helps to all who have a balance problem.
Mar 02, 2010 | Washing Machines
Wil not start
you may have to center the tub and reset the off balance switch by opening the lid all the way and centering the tub
Feb 26, 2010 | Speed Queen AWS45NW Top Load Washer
Tub knocking - shakes house when spinning
its banging on the sides, your load of clothes is out of balance,open the lid and balance load and restart machine,if you don't it will soon ruin the tub water seal at the bottom of tub
Oct 16, 2009 | Washing Machines
Washer making loud noise. Shuts off, not draining.
It appears that you have an imbalanced load, or a nearly balanced load with a machine that easily goes off balance during spin. I would suggest:
1. After the unit trips on imbalance and stops spinning, open the lid and redistribute the laundry load inside to balance its weight equally around the interior of the drum. Note that cotton fabrics hold much more water than synthetics, and this has resulted in imbalanced loads even though they visually appear to be balanced. Close lid to restart spin.
2. Remove the front panel and check both tensioning/centering springs on the sides of the tub. A loose spring could easily cause the machine to go off balance.
3. Finally, check the main bearng play by holding the drum steady and moving the top of the agitator spindle horizontally toward the rim of the tub. Any excessive play is a clear indicator that bearing is excessively worn and may be resulting in an unbalanced load.
Oct 05, 2009 | Maytag Washing Machines
Balance spring fell off washing machine. Where
Check the Sears parts site for diagrams of all the major components. Replace the model number shown (11020802990) with your model number (found on cabinet when you open the lid)
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11020802990
Look at the diagram for the machine base and you should see the springs and where they connect.
Sep 14, 2009 | Kenmore Washing Machines
Washer quit mid cycle
open lid pull tub to you till you hear a click(when you have an off balance load the tub will trip the switch)
Aug 22, 2009 | Maytag Dependable Care LAT9706
For the past several weeks the washing machine would quit once the tub was full of water. With a "gentle" opening and closing of the lid, the machine would resume it's cycle. Last week, it quit for the...
Open the control panel and check the fuse inside at the lid switch. Also check continuity on the lid switch and the micro switch. They are all located in the same lid switch block.
Check the position of the plunger that activates the lid switch. It can become dislodged with a off-balance load.
Aug 05, 2009 | Maytag Washing Machines
Washing machine
WASHING MACHINES HAVE SPRINGS ON THE BOTTOM OF THE TUB THAT ARE MENT TO KEEP IT FROM SHAKING, LIFT THE LID BY INSERTING A SCREW DRIVER SIDE WAYS BETWEEN THE LID AND THE FRONT THEN TURN THE SCREW DRIVER, NEXT UNDO THE SCREWS ON THE RIGHT AND LEFT HOLDING THE FRONT ON TO THE MACHINE, NOW IT WILL SLIDE OFF AND YOU CAN SEE THE SPRINGS
Dec 18, 2007 | Estate TAWS800JQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
119 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
