Convert Sony TX100V 1080/60p MTS to AIC MOV for iMovie 11 and keep the raw quailty
The Sony DSC-TX100V is on the iMovie '11 compatibility list, But it's a AVCHD 1080/60p camera -- iMovie '11 supports only 30fps! The Sony DSC-TX100V another option for 1920 x 1080/60i which equates to 60 interlaced fields per second, but the video quality of 60i recording mode is not better than 60p mode, so personally i prefer to choose 1080/60p for recording mts footage.So if I want to edit Sony DSC-TX100V 1080/60p .mts video with 60fps high quality for iMovie 11 on Mac, must to convert Sony DSC-TX100V 1080/60p .mts files to iMovie 11 before editing.
After google search , I need
convert my Sony DSC-TX100V 1080/60p .mts to Apple Intermediate Codec MOV for iMovie 11 with keep the raw quailty, I found Final Mate for Mac is the recommended can convert Sony DSC-TX100V 1080/60p MTS to 1080/60p AIC MOV for editing on Mac. Then I download and try it. And I had succeed with the Apple Intermediate Codec at 1920x1080 60fps editing for iMovie 11 and i'm very satisfactied with the output quality after uploading the videos on Youtube.
Here is the step-by-step guide to quickly
convert Sony DSC-TX100V 1080/60p MTS to AIC 1080/60p (*.mov) for editing in iMovie 11 on Mac.
Step 1. Directly download 60fps .mts files from Sony DSC-TX100V to
Aunsoft Final Mate for Mac.
Connect Sony DSC-TX100V to PC via USB cable. You will face the pop-up message asking you to use camcorder wizard or not. If you do not get the message, just click the Wizard button. Click Yes and follow the wizard to download/import 1080p files to the program.
Step 2.
Create a Movie for Converting Sony DSC-TX100V 1080/60p MTS files to AIC 1080/60p MOV.
Method 1): Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created.
Method 2): Click downlist of Add button and select for conversion. A blank movie is created. Then drag and drop your Sony DSC-TX100V 60fps .mts files to such a movie for merging together and making a conversion.
Step 3.
Export AIC MOV video file.
Click the Export button and choose "Export into Editor". Follow iMovie and Final Cut Express > Apple Intermediate Codec (AIC) (*.mov) to choose export format for further editing in iMovie. In this way, all video clips will be merged as one single movie for convert to iMovie.
Tips: You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 60, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality.
After the conversion, the AVCHD videos could be imported and recognized by Mac iMovie 11 with 60fps highest quailty. And after editing you can upload the best quailty .mts files to Youtube for share.
Tips: The Final Mate For Mac support camcorder includes but not limited to Panasonic HDC-TM900,TM90,SD90,HDC-TM700/HS700/SD700, SD60/HS60, DMC-GH2,GH1,GF2,ZS7/TZ10; Sony HDR-CX700, CX550, XR550, XR520, CX350, CX305, CX150,CX360, Alpha NEX-5,DSC-HX5V,; Canon Vixia HF200, HF S100,HG10,HG20,HF R10,HF R11,HF R100.etc If you want to know more about Camocorder , plaease visit the
Camcorder column for more information.
