Washing machine leaking oil
I moved my maytag out from the wall to clean the floor and found the floor cavered in oil. Whats up? I didn't know that washers had that much oil in them.Whats leaking? What Part? Thanks for any suggestions I can't afford a repairman.
  • Anonymous Mar 16, 2014
    oil on floor from maytag washing machine
Your washer has a transmission and this is what is probably leaking. You might simply need a new seal or the a new transmission. You need a good handyman or contact a repairman.
Posted on Dec 02, 2008
Red fluid leak in maytag washer la712
Sounds like gear case oil. Dark Red? Did you tip the washer over?
Sep 03, 2012 | Maytag Washing Machines
Maytag washer is leaking oil on the floor??
The transmission is bad if it is leaking oil.
Feb 14, 2010 | Maytag Dependable Care LAT9706
Grease spot found on the floor from the right side
There is a bearing seal that does tend to leak. Feel free to ask any other questions. I do recommend copy and pasting this link in your internet address bar under a new tab for more great repair info:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 13, 2009 | Maytag LAT3600A Top Load Washer
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
My maytag neptune washer is very very loud -- I just moved and hooked it up -- it has never been loud before, but is so loud now that it hurts your ears to be in the same room. could this be a bearing...
IT WELL NOWN ON THE NEPTUNE THE BACK BEARING GO OUT AND IT VERRY EXPESEVE TO FIX YOU WILL NEED THE OUTER TUB AND THE TRYPOT ON THE INER TUBE PARTS GO GO UP TO $500.00 THE OLY THIG YOU CAN DO TRY TO PUT OIL ON THE BACK TAKE THE BACK CAVER THER ARE 4 1/4 SCRES AND IN BACK OF BIG PULLY ON PLASTICK HOUSING THERS A SMALL HOLE PUT ANY TIPE OF OIL
Jul 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag floods when it drains
If the flooding is from hose and joint in the drain system, or from the drain pump, then it is the machine.
If instead, as it looks, it is a return from the drain pipes on the wall, then the problem concerns your house drain line, in that case it is a plumber job.
Ensure that the leak is not from inside the machine, if it is not anything from the machine, then call the plumber.
Jan 05, 2009 | Maytag HAV3460AWW Top Load Washer
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Water out of washing machine.
Sounds like the machine is not at fault. The problem is probably the pipework that takes the water out of the building, it could be made up with lime & wash powder residue. Try running some water into the wall outlet pipe, & see if it overflows, if it does you need to dismantle & clean it
Oct 26, 2007 | Maytag Performa PAV2200
Washing Machines Logo
551 people viewed this question
Top Washing Machines Experts
