Question about GE Profile JTP56 Electric Double Oven
GE DOUBLE OVEN MODEL K25003DC
LOOKING FOR DOORS IN STAINLESS STEEL. WANT TO MAKE THEM LOOK MODERN. HOME WAS BUILT IN THE 1970'S. WHERE CAN I FIND 2 DOORS?
    Champion:
  • 246 Answers
Go to www.applianceart.com and check out their instant stainless material for refacing your existing doors and getting the stainless look you desire.
These guys can assist you with the whole process. Worth checking out.
Posted on Nov 02, 2011
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
I HAVE A DOUBLE OVEN GE MODEL JKP55DPEWW WHITE AND WANT TO REPLACE THE DOOR WITH STAINLESS STEEL,PLEASE HELP
When I removed the front cover there were other color door fronts stored in side. I would just order a SS door front from a dealer or parts supply house
Apr 30, 2014 | Ovens
We just purchased a home that was built in 2003. It has a stainless steel double oven. The doors don't close tight. Is there a way to adjust them so they do? Thanks
I have the same problem on my AOCS3040 oven....door will not shut tightly so it loses heat and is about 25 degrees off plus the escaped heat makes the control panel get very hot during cooking.
Oct 21, 2010 | Amana AOCS3040 Electric Single Oven
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Stainless steel on doors marked from the protective covering, can not get marks off
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Jan 02, 2010 | Maytag 30" Built-In Double Electric...
I have a 10 year old GE profile dbl wall oven that I love BUT with a new Stainless fridge, cooktop and dishwasher the wall of white oven is a glaring mis-match. The oven doors both have exterior white...
Go to www.applianceart.com and check out their instant stainless material which is perfect for refacing your existing appliances and getting the stainless look you want without the stainless pricetag.
Contact these guys with any questions you may have.
Oct 18, 2009 | GE Profile JTP56 Electric Double Oven
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ge double oven
I believe this is because it takes a while for your oven to cool down (the cleaning cycle uses a very high temperature to burn up the grease and food). The timer is how long it takes before it will be cool, at which time the oven will unlock.
Mar 17, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE Profile JTP56 Electric Double Oven Logo
177 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
