Question about Philips Magnavox 51MP392H Rear Projection Television
Bocma IC TDA888xx 8V failure
What is a Bocma IC TDA888xx 8V failure?
  • joe
    joe Jul 30, 2008
    Phillips just informed me that the 9 blink in HDTV sets was most likely the core processor which is also a BOCMA IC thats a thirty Pin IC on the Signal board.
    Where can I find that board. What part do i need to replace?
  • Philips Master
  • 8,617 Answers
Usually related to the vertical deflection IC in the DPTV series phillips / magnavox. The Vertical deflection is a BOCMA family IC
Posted on Jul 30, 2008
  • Sonny Berry
    Sonny Berry Jul 30, 2008
    Thats on the Picture in picture (PIP PCB) but that doesnt usually shut the set down, that can make the set experience abnormalities in the split window functions, I would think its the Vertical deflection as thats a BOCMA IC as well, and that will shut the set down.
Samsung tv off after few seconds
there is a power regulating ic (5v,8v,3.3v) you have to replace that ic new &check
Feb 01, 2012 | Samsung SlimFit TX-S3082WH 30" TV
VW Golf camshaft sensor failure diagnosed. What price does this normally cost to buy and replace, in general.
$54.95
This one is for a 2.0L 4cyl 8V application found at most popular VW internet stores. Very simple to install although requiring some mechanical ability to tackle this work.
May 19, 2010 | 1991 Volkswagen Golf
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Sony Ericcson w580i
if your firmware is CID53 then you have to try online at topsony.com or take the phone to a mobile service center to hvae that done.
May 26, 2008 | Sony Ericsson W550i Cellular Phone
Kenwood KVT-715 Radio not working
I would be willing to bet you have a 8v regulator circuit failure in hideaway Box. I have seen many of these units where a resistor opens and causes 12v instead of 8v to appear at tuner and a few other IC's. Usually But not always destroys tuner.
kstahl65@att.net if there are questions
Apr 14, 2008 | Kenwood KVT-715DVD Car DVD Player
Kenwood kvt 715dvd
I have seen problems in the hideaway (brain) where 8v reg circuit fails causing higher voltage(12v to 14v) to be on that 8v line. First component to fail is the Tuner followed by electronic volume ic. I have probably seen 6-8 failures where tuner fails. Fix is to replace tuner and replace open chip resistor in Hideaway box to restore 8v regulator to proper voltage. kstahl65@att.net
Feb 24, 2008 | Kenwood KVT-715DVD Car DVD Player
ABOUT PHILIPS TELEVISION
The 8V at pin 36 won't show unless there is oscillation, the primary voltage pin is pin 10, 8v. Don't mind me asking, you have checked the B+, right? Because the blinking LED is often because of power supply problems. And if that's okay, desolder the horizontal driver output legs and connect an LED to find if it is oscillating, if it does, forget the ic part and move on with the FBT and things. Good luck.
Jan 31, 2008 | Televison & Video
Sony FD Trinitron colur television KV-29LS30E
When i set the TV on it's not open but the red led lights on-off 11 times.In service manual said than the error is in 8v in jungle I.C .That means the jungle IC is off?
The 8v comes out from jungle I.C or the power supply?
THANKS
Jan 15, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No eht
Disconnect the horizontal driver transformer output pins and connect an led there to find the it is oscillating, if it does, then it could be the LOT. Try replacing the oscillator ic if there is no oscillation.
Dec 28, 2007 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
