Question about Samsung Office Equipment & Supplies
How do i fix an error E8 from a samsung ER 350 till
  • Anonymous Feb 26, 2009
    Samsung er-350 the same problem e8 and beeping how to fix ?
4 Suggested Answers
  • 1019 Answers
SOURCE: Samsung ER-220 cash register till user guide
This model is obsolete.
The nearest you,ll find is Here:-
http://www.tnt-gifts.com/cash-register-manuals/samsung-cash-register-user-manuals.html
Mike @ compurepair.
Posted on Mar 15, 2008
hokuwho
  • 306 Answers
SOURCE: my samsung till won't talk to my lap top
Windows Vista is the last operating system that you would want to use for legacy hardware -legacy being anything that requires a usb to rs 232c adaptor. Scripts required to make this work would drive you to an abacus. If you need to have a cash register input on a permanent basis I would recommend another operating system, even a real old computer would be easier to interface or you could use the modem output of the Samsung to connect to your laptop in a LAN configuration maybe even with a null modem connection. Vista will drive you crazy with permission denials with cries of cyber-sodomy with an analog interface directly connected. The Samsung 755 has a USB interface but since you don't have the correct input for your laptop it will be far easier to use the cash register an an old (cheap) computer with an RS 232 interface and connect it to your laptop with a wired or wireless LAN configuration. Those USB to DB9 0r DB25 or PS2 adaptors still cannot match the speed parameters that the laptop US Host controller would ever find acceptable. Windows XP or 2000 might be a consideration but Vista is already neurotic enough without interfaces it was not designed to accomodate. I hope this will save you from alot of frustration. respectfully, Steve Medley
Posted on Oct 14, 2008
blueextc3221
  • 15935 Answers
SOURCE: E8 error code
8E - OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My mfp m1132 is showing error E8 and cant copy/scan. what do I do?
Juliet. Most likely the scanner lamp, or scanner control unit assembly is defective. If you're technically savvy, you could remove the scan glass and lube the shaft that the scan lamp assy slides on. Sometimes that will fix it. Otherwise, the whole top scan unit will need replacing. That could cost over $300 for the replacement.
Oct 07, 2015 | HP LaserJet Office Equipment & Supplies
My samsung er 290 wont stop printing till roll
system option 21.Key on pgm press 21-RA-1-PO-CASH. Turn you key to reg and press PO. Good luck
Jan 28, 2014 | Sam4s Samsung Er-290 Cash Register
Samsung er 650 cash register
maybe the keys is broke or your cp is broke...Try go some expert to fix your samsung
May 30, 2013 | ErrorExpert
I am getting an E1 error message on my Samsung ER-3715...I need a solution ASAP!!! I have a line of customers!!!!!
turn key to mc.. switch off.. holding down CLEAR not c.. switch back on should print CS on till roll.. then turn to pgm and program as needed..
Jul 18, 2011 | Computers & Internet
52 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
