Question about Xerox Phaser 8200 Laser Printer
Phaser 8200 will not start up
My Phaser 8200 will not start back up after having had it shut down for a couple months. I replaced tha maintenance kit & it goes to XEROX in the screen and that is all. I hear fan running.
  • Anonymous Dec 18, 2008
    Same problem here after a 4 day power outage.
  • rscott_young Jan 07, 2009
    Same problem here. The printer hangs at the XEROX screen. Turning the unit off and on 25 times worked last time. Now it won't count from 1% to 100% ready.
    President:
  • 2,072 Answers
Are you getting any fault codes on the screes? A fairly long number..
Posted on Aug 16, 2008
Maintanance kit replace sp 8200 dn
Hi Shrife,
Although you might have this problem cleared by now, Ill try and add more information that might be of help.
Once you replace the maintenance kit there is a small CRUM Chip on the side of these units to record the life of them and can be used monitor how long units have been used for then the printer can remind the user when to order a new unit.
If you have a bad connection then the unit won't register and work.
If you have a faulty unit you must let the supplier know and they should send you another.
Good Luck.
Apr 10, 2014 | Xerox Phaser 8200 Laser Printer
How do I replace a Transfix Assembly
There should be a door on the right side of the printer. Replace the maintenance kit and clean the waste ink tray.
Apr 14, 2012 | Xerox Phaser® 860, 8200 Standard Capacity...
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8860 says "Maintainance Kit is Missing"
Most likely it needs service. Here is the service provider finder from Xerox.
Aug 24, 2009 | Xerox Phaser 8500/DN Printer
XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Reset counter on Xerox Phaser 8200
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
Printing Problems
That is known as paper skew. It normally comes from A. Worn or dirty rollers either in or just past the paper tray.
B. The paper tray itself. C a spring off a roller not allowing even pressure on the paper, or D, the registration clutch which is responsible for stalling the paper long enough to square it in the machine.
For some reason the paper is twisting from uneven drive to the right side of your print as seen in the photo. Could even be a slight obstruction aka a piece of a label or tape that somehow is in the paper path causing the paper to drag in that area.
Normally skewing ( twisting ) of the paper it pretty easy to cure. I am suspecting with a 5 year old machine, some slick rollers first, then a spring/pressure problem on some roller.
Let me know, We can fix this one.
Jun 11, 2008 | Xerox Phaser 8200 Laser Printer
Paper is printing but top edge of paper is creased and torn
It sounds like your maintenance kit is defective.
The excess oil leads me to believe that.
Jun 04, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 8200
Normally its the maintenance tray clutch slipping.
Or the maintenance tray ends are worn.
You can remove the left cover and clean the clutch, its on the lower part of the frame, and take your kit out and there are 2 tabs sticking out the ends that were on the last 1/4th inch.
The Printer's Front Panel Displays Printer Error - Report Fault: 07,005.47
Cause:
The Drum Maintenance home sensor actuated, but not at the expected time. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts): The wiring harness from the clutch is not seated properly on the I/O Left board. Check all wiring connections to the I/O boards and verify. connectivity. TROUBLESHOOTING TIPS AND HINTS: Inspect the maintenance drawer lift pins for wear. See Service Bulletin #445 Rev #1 Replace Drum Maintenance Cam Followers for Inadequate Drum oiling Due to Worn-out Lift Pins. Run diagnostics to verify clutch and sensor operation. Also verify that the drum maintenance shaft is properly assembled. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 401087100 1 CLUTCH; LARGE,DM,SAFETY CONTROLLED 436041400 1 MAINTENANCE DRAWER W/10K ROLLER & COUNTER/PHASER 860/8200 367051501 2 FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1
May 05, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
142 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
