RCA HD52W58 52" TV Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn the tv on with the remote the power button blinks on and off three times, never turns on. I have to do this several times before it actually turns the tv on.
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 100 Answers
  • Posted on Mar 02, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
100
Questions
0
Helped
16101
Points
235
Hello, Is after the TV turns on, it continues to work as usual
How do I program this RCA nightclub universal remote for my Samsung smart TV
First understand that you need a little patience with this remote, it's a little slow, it may take a few seconds in between pushing buttons for it to react to your TV.
1)
-Turn on TV manually first.
we're going to try and get the remote paired to your particular tv
2)
-Facing RCA universal remote towards TV, press and hold both the POWER and TV buttons on the remote at the same time.. until the RCA universal remote POWER button lights up and is constantly on.
-Then press the PLAY button on RCA universal remote
(POWER button on remote should be blinking after pressing PLAY -- what the remote is doing is trying to program your TV with a list of codes. if your TV does not automatically shut off after a minute, press the PLAY button again. your TV should shut off. wait a few seconds before trying to press PLAY button again if you need to try again.)
3)
Assuming remote turned off TV. Now let's try to get the remote to turn on your TV
On the remote at top right is a REVERSE button, press that. You should see the POWER button on the remote blink once in response to you doing that.
Watch for the power on light on your TV.. your TV may take a few seconds to power on..
Wait a couple seconds. if your TV has not turned back on, press the REVERSE button again. the POWER button should blink once again in response
If your TV did not turn on. You may have to repeat pushing the REVERSE button waiting a couple seconds for the remote to try turning on your TV. For some people this can take several times, if not a dozen times. Just be sure to be patient and wait a couple seconds in between pressing the REVERSE button again. (what the RCA universal remote is doing is going through a list of codes trying to find the right model to pair to)
4)
Assuming the remote finally turned on your TV.. We are almost done. We programmed the remote to turn off the TV and turn on the TV. now we want to press the STOP button on the RCA universal remote to lock in those codes into the remote. After pressing the STOP button the light on the remote POWER button should turn off.
5)
We are done. You should be able to change the channels and raise and lower the volume of your TV.
1helpful
My old Bell receiver 's remote was an IR Remote. How do I program the new UHF PRO Bell remote?
mikecrans175
I have provided the instructions on how to program your remote to your TV and addressing the remote to your receiver below. I hope this helps.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and Hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote:
  1. Go to System Info screen.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL #26LV61OU LCD-HD AND IT DIDN'T HAVE A REMOTE. IT'S WORKING WITH MY VERIZON FIOS BUT I CAN'T CONTROL THE SOUND. WHAT TYPE OF REMOTE SHOULD I GET FOR THIS T.V. AND...
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
  3. Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
  4. The lights for each device button light up and the light for the device button you selected remains on.
  5. Press the Power button on your remote.
  6. The device button blinks three times then turns off.
  7. Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
  8. Did the device turn off?
    Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
    No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
    Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
  2. Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
  3. Press 991.
  4. The mode button blinks twice.
  5. Point the remote control toward the device you are setting up and press the Play button.
  6. The remote control tests each code in its library. The mode button blinks once each time the remote transmits a new code. When the last code is reached, the mode button blinks twice.
  7. When the device powers off, press the Select button.
  8. Verify the new code is correct by pressing the Power button.
    Did the device power on again?
    Yes: Press Select to assign the code in your remote control.
    No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
12helpful
3answers
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
1helpful
I'm having a problem with my Panasonic PT-53wx52
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
2answers
Universal remote wont work with this TV
Questions: Who is "Sansui", the digital box ? or the TV? Is the "digital box=remote control"? turn on what you want to control.
Face the RC face down or away from TV,or whatever you want to control. Usually:: push & hold TV & SEARCH button until light blinks, two, three times? FACE THE TV and put the code for the [TV=Sansui ?] You said #189 try 0189 [zero,one,eight,nine]
2nd) TV power ON!,....HOLD down (and if you have a SEARCH) button and the tv power button on RC, two or three blinks, push up arrow once, press power button for TV on RC, nothing!, continue...up arrow, power button. when the TV turns off, you have found the code,. YOU MAY HAVE TO DO THIS 50-150 TIMES because the RC is looking through EVERY code!
Sometimes
1helpful
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
Remote code
Magnavox 0054, 0706, 0030, 1454, 1254
How do I program my remote control?
For remotes that have blue arrow and Select buttons and 4 separate mode buttons (SAT TV VCR AUX):
*If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again.
  • Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
  • Use the number pad buttons to enter the three-digit number corresponding to the equipment (click here to view remote codes). The light will blink off after each digit is entered and then return to a steady light.
  • Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment.
For remotes that have one Mode button at the top:
*If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over.
  • With the desired equipment on, press and release the Mode button until the light flashes behind the correct mode.
  • Using the tip of a pen or the eraser on a pencil, press the address button.
  • Enter the code (see links to find your code below) on the remote's numbered keypad for the equipment.
  • Press the Address button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment. Some codes may provide partial functions or respond differently than the button's titled function. Try the other codes listed for that device until you find one that offers more complete functionality.
Click here for codes for remotes with blue buttons.
Click here for codes for remotes with gray buttons.
Click here for codes for platinum (DVR) remotes.
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
