2001 Ford F250 Super Duty Super Cab Logo
Posted on Mar 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need instructions to remove the front rotor on F250 Four wheel drive truck - 2001 year
Anonymous
Level 3:
  • Ford Master 1,940 Answers
  • Posted on Mar 02, 2011
Anonymous
Ford Master
Level 3:
Answers
1940
Questions
0
Helped
954087
Points
5951
  1. Raise and support the vehicle; Remove the wheel and tire assembly;
  2. After removing the tire, remove the brake pads;
  3. Remove the disc brake caliper by removing the two disc brake caliper pin bolts. Lift the disc brake caliper from the disc brake caliper anchor plate (2B292). If necessary, remove the V-springs.
  4. Remove the pads. Remove the front disc brake caliper anchor plate stainless steel rail clips.
  5. Remove the rotor.
  6. Note: Perform this step for DRW vehicles. Remove the eight hub extender nuts, the hub plate and the rotor. Remove the eight hub plate nuts. Remove the hub plate. Remove the rotor.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2helpful
How do you tear down front hub on 4 wleel drive truck?
FRONT DRIVE AXLE Manual Locking Hubs DISASSEMBLY AND ASSEMBLY Fig. 1: Three screws retain the cap to the hub body 91197g48.gif
Fig. 2: Remove the lockring seated in the groove of the brake rotor assembly 91197g49.gif
Fig. 3: Remove the hub body assembly from the brake rotor assembly 91197g50.gif
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the three screws retaining the cap and remove the cap from the hub.
  4. Remove the lockring seated in the groove of the brake rotor assembly.
  5. Remove the hub body assembly from the brake rotor assembly. To install:
  6. The installation is the reverse of the removal.
How do you remove the Hub and Rotor on a 97' F250 with Auto 4 wheel drive? I can not get the rotor to come off. I know that the hub must come with it. However, I am not sure what I have not removed in...
Section 05-03C: Wheel Hubs and Bearings, Front Wheels, 4-Wheel Drive 1997 F-250/350/Super Duty Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/17/2000 Locking Hubs, Manual
Item Part Number Description 1 3A329 Halfshaft 2 3C132 Rolling Diaphragm Seal (Axle) 3 3299 Integral Spacer Needle Bearing Seal 4 3123 Bearing, Caged Needle 5 3105 Front Wheel Spindle 6 1190 Wheel Hub Grease Seal 7 4221 Inner Wheel Bearing (with Bearing Cup 4222) 8 1102 Front Disc Brake Hub and Rotor 9 4221 Outer Wheel Bearing (with Bearing Cup 4222) 10 - Pin (Part of 1195) 11 1195 Inner Lock Nut 12 1198 Lockwasher 13 1197 Outer Lock Nut 14 - Steel Thrust Washer
(Part of 3B458) 15 - Plastic Thrust Washer
(Part of 3B458) 16 - Splined Thrust Washer
(Part of 3B458) 17 3B457 Snap Ring 18 1K105 Hub Body 19 - Lock Ring (Part of 1K106) 20 1K104 Cap 21 1K104 Capscrew A - While Rotating Front Disc Brake Hub and Rotor, Tighten Inner Lock Nut to 68 Nm (50 Lb-Ft) to Seat Bearings. Back Nut Off 90 Degrees (1/4 Turn). B - Tighten to 217-278 Nm (160-205 Lb-Ft) C - Tighten to 4-6 Nm
(35-53 Lb-In) Removal
  1. Separate cap assembly from hub body by removing the three Torx® head capscrews.
  1. Remove the lock ring seated in the groove of the front disc brake hub and rotor (1102).
  1. Remove the hub body assembly from the front disc brake hub and rotor. If the body is difficult to remove, install two capscrews and pull the body assembly out of the front disc brake hub and rotor.
Installation
  1. NOTE: Do not pack the hublock body assembly or cap with grease. Excessive grease can cause excessive dialing effort and hub failure.
    Follow removal procedure in reverse order.
  1. Tighten three Torx® head capscrews to 4-6 Nm (35-53 lb-in).
I need help on my 2001 f250 for the front axle bearings and seal
Remove the wheel. Remove the two bolts at the caliper. Take a C clamp prefferbly a 6 inch type and compress the brake pads as far as they will go into the caliper.
remove the caliper
Now remove the two bolts to the calipers saddle that holds it in place
I think a 17 mm wrench will do
Now you can remove the rotor by removing the bearing cap and the rest is easy to figure out by punching out the bearing races as well as the seal
Clean thoroughly before installing the new parts
2answers
How do you get hub assembly off of a 1999 Ford F-250 super-duty Four Wheel Drive with ABS breaks?
remove brake caliper, rotor, axle nut and four bolts on the back side of the knuckle
1helpful
Rear wheels on 2000 super duty f250 skid in reverse only
I hate to say it but it sounds like you have a severe problem in the rear end. Here are a couple of things i would do. First pull off your tires and wheels. Of course you need to put the truck on jack stands and block the wheels for safety! Disconnect your rear drive line so you know nothing from front diff or trans could be affecting it. Next spin the brake rotors by hand and inspect them for severe damage. Go forwards and backwards. Also listen in your rear end for grinding or clunking noises and also excessive play front foward to reverse. And last drain your oil and put your finger up inside the housing as far as you can and feel for large pieces that should not be there. This should give you a good idea if it is in your braking sytem your rear end or wether you need to start looking at front diff. or the trans. If all is good on rear end do the same thing for front diff and inspect it as well. Make sure you pull front driveline off!
While driving, four wheel drive quit working. It
Check the fuse for the four wheel drive before taking another step,it is electrically engage,hope that help you and clear your mind
2answers
Ford F250 SD, 2wd. Replacing front bearing
If you have front disk brakes you have to remove the brake caliper to get the rotor off.
2helpful
Replacing front rotors
you do have to dissasemble the hubs because the rotors bolt on to them. if it is two wheel drive take the center caps off of hubs remove the spindle nuts and bearings pull complete hub assembly off and unbolt rotor from hub. if it is four wheel drive you will have to remove the lockout assembly be careful not to loose any parts from this it won't work when put back together.
2003 dodge truck
Probably bad u-joints. I am not a mechanic, but just replaced mine. You may want to jack it up, remove the tire and spin the hub while looking at the u-joint right there behind the rotor. Obviously there are 2 u-joints, one for each front wheel. Not all that hard to replace, call me if you want some tricks that I learned the other day.
Chris
630-549-0155
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
