Question about Toys
Ride on thomas peg-perego
Hi i bought the thoms train when u push the music button it plays but when u push the button to make it go arond on track it just makes a bell nosie and does not move and when u plug the charger in the charger has got no light
  • 4 more comments
  • fixthomas Aug 09, 2008
    I'm having the same problem. The music works. When you push the acceleration button, it rings the bell and nothing. Did you find anything out?
  • mjmoosle Nov 06, 2008
    Hi, I just bought this train also and am having the exact same problem. I bought it slightly used, so it did not come with a manual or instructions. Were you all able to figure out the problem?
  • bernabemgirl Dec 05, 2008
    My problem is that I charged the battery overnight and the next day, it did not do anything at all. It had been out of use for a while maybe 6 - 9 months, but I don't see why that would cause a malfunction.
  • Anonymous Jan 13, 2009
    ditto
  • Jmandoki Jan 27, 2009
    I just bought it used and the buttons work but the train isn't moving... It turns the light on but the motor doesn't go....
  • somebyrd Apr 06, 2009
    Exactly the same but no bell sounds, just get a "click"  We took the first one back to the shop and exchanged it but this one now well out of warranty, grrrrrr!
    Sniper:
  • 80 Answers
Sometimes the battery and/or the charger can go bad. If the battery is less than 6 volts on a multimeter, it won't operate for long. Is the headlight bright or dim? Remember that the button has to be held down to run. Releasing the button will stop the train.
If neither of the above works, you may want to order a new circuit board from tigerimports.com.
Posted on Mar 31, 2009
    New Friend:
Have you pushed the gear stick into forward and reverse in the side of engine?
Posted on Jan 17, 2013
  • 38 Answers
Well the might be a malfunction with the motor. do any other noises come from the toy when you press the go button.
Posted on Jul 31, 2008
I have a peg perego Thomas the train ride on and music will come on but it will not move
It's probably the circuit board that you can get here http://www.mypegperegoparts.com/meva0024.html but you can also contact their repair desk 1-801-655-0800
Apr 13, 2017 | Peg Perego Toys
Thomas train shows as fully charged however when trying to use it, music starts but then a clicking noise and train doesnt move
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
Jun 25, 2010 | Peg Perego IGED1084 Santa Fe Train
Thomas train peg perego instructions
have to hold on the button that has arrow untill it moves
Apr 03, 2010 | Peg Perego Ride On Santa Fe Train
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Dec 16, 2008 | Peg Perego Vespa Scooter
Peg Perego Thomas the Train Ride-on Music button not working
It could be a bad switch or the music board has a bad contact.
Nov 21, 2008 | Peg Perego Vespa Scooter
Toys Logo
2,485 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
