My Sharp Aquos has lost it's picture brilliance on all channels.
  • 1 more comment
  • sinckins Jul 29, 2008
    model #37-d4ou
    I've tried all settings with no response. Can I replace the crt board myself? Where can I get one in Oregon?
    Low brilliance on my Sharp Aquos lc37-d4ou. Tried all settings with no reponse. If I need a new crt board can I replace it myself?
  • 4,234 Answers
First of all the model you posted is an LCD set, there is no CRT nor a CRT board. The question is this: is the picture clear but just dark? If so, the "back light" is starting to fail. This can be either the panel itself (expensive) or the power supply (more likely). The power supply module is available at tritronicsinc.com for $133.38 using part number: RDENCA161WJQZ.
Keep us posted.
Dan
Posted on Jul 29, 2008
  • 10,594 Answers
How old your TV is ?
  • 19,396 Answers
Try adjusting picture settings from tv menu, if this does not work your tv has a bad crt board in need of replacement
  • Ginko
    Ginko Jul 29, 2008
    Sometimes this also happens when some magnet ie,headphones, pwer adapters etc. come to close to your tv in this case problem is temporary.
    To replace the board you need to work inside tv, on some model some soldering job is also involved.
    You will need to unplug tv power one hour before working inside tv, because of risk of electrostatic charges.
    My suggestion is to contact a technician and have the job done by a professional.
    You can buy replacements here . Enquiry seller if part is not in list.
Sharp aquos lc32l400x
It is a recommended practice to repeat the channel search routine periodically as the DTV environment is subject to change. Also, the antenna connection to your TV may not provide sufficient signal strength to maintain picture quality. Even weather can be a factor.
Jan 16, 2014 | Televison & Video
NEED TO GET BACK ON DISH SAT. LOST CHANNEL
either hit the input buttons to see which input the cable is on or flip through the channels to find the one with the picture or call the company for what channel it is on if the inputs doesn't work
Apr 05, 2011 | Sharp AQUOS LC-40C32U 32 in. LCD TV
We have a new 46" Sharp Aquos with a "snowy"
sounds like you have a cable connection problem make sure your tv is set to dtv signal in the menu screen. when you scan the channels should be displayed as 12.1 or 8.2 not just a single number if the digital channels are programmed correctly then change the cable coming into the tv from antenna making sure that it isnot crossing any power wires good luck and hope that i helped
Nov 07, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Picture but no sound on two cable channels. All
Make sure under the Audio Menu that you have SAP turned OFF
Jul 09, 2009 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
Apr 29, 2009 | Sharp Aquos LC-32D40U Television
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
52 inch aquos sharp tv
Just bought a 52" Aquos TV 27000/1 newest model for 2008 my husband is putting it up and said the non HD channels don't look real good. Is there anything we can do to improve the picture on the non HD channels?
thanks,
Cathy
Dec 06, 2007 | Sharp Televison & Video
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
