Question about SkyGolf SkyCaddie Handheld GPS Unit
Device Not recongnized by windows
I have a Skycaddie SG3 and when I try to connect to my laptop I receive a USB error stating that the device has not been recognized by windows. I've tried to connect this to 3 different computers with the same results
  • JeffLH Aug 13, 2008
    Thanks, that's what I'll do.
    Problem Solver:
  • 8 Answers
Be sure the cable that connects to the back of the SkyCaddie is plugged in correctly and that is going straight down the back of the SkyCaddie over the logo. The cable should not be coming out of the top of the device then down, that will cause the error you are getting. If this is NOT the issue or the resolution, then unfortunately, anytime a device reads USB not recognized or malfunctioned, you will need to send the device in for a repair, IT IS an internal issue.
Posted on Aug 12, 2008
My sky caddie sg5 won't charge thru the usb or power cord...any ideas???
Hello there,
Since you have tried charging the device using the usb and the power cord. It is quite clear to know that the problem is from the device connection port. It is bad and need to be replaced.
But you need to Try to test the battery in other devices then try to charge it there to see if it will hold a charge. If the battery holds a charge there, then it means the battery is okay and if it does not charge. Then it means the problem is from the battery. It need to be replaced if so.
Then test the charger/ power cord on another device if it is not bad, then you test the usb cable also. After running these test. You will be clear to know if it is the connection port. Then replace the connection port once confirmed to be the problem. Hope this helped. Goodluck Elect_Comp
Sep 02, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
I can not get my sky caddie to register and I do not get an icon on my desktop.
i have been trying to register my new sg3 as stated in manuel also wanting to buy a eagle pakage been trying to for a week.if not able to today will be sending back paul herbold
Aug 16, 2010 | SkyCaddie SG2.5 GPS Receiver
Where can I find a SG3 SG4 USER GUIDE?
You can refer the instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 23, 2010 | SkyGolf SkyCaddie SG4 GPS Receiver
Will not recongnize usb devices when they are attached. I receive a message that there is an issue with the usb device I connected. The device I am testing with is a Logitech mouse that works on the last...
Have a look in Control Panel> System>Hardware> Device Manager and expand the entry 'Universal Serial Bus contlollers'
Right click entries here and select 'properties'
This might show up a problem and will also enable you to update drivers if necessary.
Apr 01, 2010 | Toshiba Satellite P205D-S7802 Notebook
Sky caddie will not sync. error reads your SkyCaddie colud not be found.
plug in your connection cable to the back of the skycaddie with the cord going down towards the battery, not up. This should fix the USB recognition issue.
Jul 26, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
SG4 Sky Caddy driver
Make sure your cord is plugged into the SkyCaddie with the cord pointing down towards the battery, not going up. It makes sense and it is easier to plug in with the cord going up, but you will eliminate this error if you plug in the cord with the cord going up.
Apr 02, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Sg4 problem
This may sound crazy but I had the cable connected incorrectly (I was getting a message that my Sky Caddie SG4 was unrecognized). When connected the cable correctly (to the back of the SG4) the cable wire should be pointing down.
Thats all it took to fix this issue for me.
Jul 03, 2008 | SkyGolf SkyCaddie SG4 GPS Receiver
Cannot get direct connect to work
please check your power y cable cord the comes with the sg3/4 units. they have teeth or tabs on it near the screw and they tend to break if it slips while the person is trying to screw it in. that will cause the unit to not connect no more and they will need to replace it, but please don't use a broken power y cable, it will cause it to slide around and shorten it out. most of the time this occurs after the person had it for awhile or they screw it in too tight and over time that will strip it out and cause it to no longer to screw in...
Jan 06, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
SkyGolf SkyCaddie Handheld GPS Unit Logo
579 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
