Contributor
- Posted on Mar 04, 2011
Re: I have a Baby Gaggia, several years old. I buy IZZO...
Please try the following:
- Remove the portafilter and activate the brew switch. Water should stream out of the shower screen. If not you need to clean the group components, or the machine is broken.
To clean the group components, remove the center screw. The screen should drop down, the dispersion disk may be stuck, you can pry it loose with a flat head screw driver. Soak both of these in a descaling solution.
- With the group components removed (as above) try brewing, water should stream out of a single hole. If not, you may have a faulty pump, or seals.
- If water streams out normally, be sure that you are using the single espresso basket. This is the smaller basket that snaps into the portafilter, and has sort of a tulip shape.
- Your group head gasket may be worn, and will need to be replaced. These need replacement ever 6 months to 12 months, and need to replaced even if the machine is rarely used, because they are made from natural rubber that dries out.
Replacements can be found at many retailers online, a few are:
espressocare.com, espressoparts.com, and seattlecoffeegear.com
