Konica Minolta Bizhub C352 error code C-0204
I recently moved my All-in-One C352 from one location to a new one I just opened, and we were extremely careful with it, and when I unwrapped it and turned it on, the error C-0204 came on. I have moved the copier before, and this never happened. What does that code mean?
  • Anonymous Apr 07, 2009
    same
I had the same recently.
Problem is caused by a paper which stuck behind the paper tray. It happens when You put to much paper od while moving (for example). Solution: take out the paper tray 1 and 2, remove the paper from the space behind the trays.
Pixel
www.mojito-networks.com
Posted on Jun 23, 2009
This works,paper behind the paper drawer,
Posted on Aug 17, 2014
Heated drivers seat dont work on my 1998 lincoln contenital
It could be the heating element or the Driver heated seat module ! Do you know anything about automotive electronic's ? Circuit testing with a DMM - digital multi-meter ? This system has a element in the seat an the back . None work ?
  • Heated Seat Inoperative
  • Circuitry open/shorted.
  • Damaged heated seat heater elements.
  • Damaged heated seat module.
  • Damaged heated seat switch.
  • GO to Pinpoint Test G .
PINPOINT TEST G: HEATED SEAT INOPERATIVE G1 TEST HEATER ELEMENTS
  • Disconnect connectors C352 LH ( C356 RH) at heater modules.
  • Using an ohmmeter, measure resistance of heater elements according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 12 1067 (P/LB) 9 1066 (GY/LB)
Is resistance of elements 2.5-10 ohms?
Yes No GO to G2 . GO to G4 .
The seat heater module is under the driver seat .
G2 TEST HEAT SENSORS FOR OPEN CIRCUIT
  • Using an ohmmeter, measure the resistance of sensors according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 11 1063 (O/LB) 10 1062 (R/LB) 6 1061 (BR/LB)
Is resistance more than 10,000 ohms?
Yes No REPLACE trim covers. RESTORE vehicle. RETEST system. GO to G3 . G3 TEST HEAT SENSORS FOR SHORT CIRCUIT
  • Using an ohmmeter connected to a known good ground measure resistance of Circuit 1063 (O/LB) at Pin C352 LH; Pin C356 RH.
  • Measure resistance of Circuit 1061 (BR/LB) at Pin C352 and Pin C356 .
Is resistance 0 ohms?
Yes No REPLACE trim covers. RESTORE vehicle. RETEST system. GO to G6 .
G4 TEST CIRCUITS BETWEEN HEATER MODULE AND HEATING ELEMENT CONNECTOR
  • Disconnect connectors C353 and C351 LH.
  • Disconnect connectors C355 and C354 RH.
  • Using an ohmmeter, measure resistance of circuits between module connector and heater element connector according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 12 1067 (P/LB) 11 1063 (O/LB) 6 1061 (BR/LB) 10 1062 (R/LB) 9 1066 (GY/LB)
Is resistance less than 5 ohms?
Yes No GO to G5 . SERVICE suspect circuit for open. RESTORE vehicle. RETEST system.
G5 TEST HEAT ELEMENT AND SENSOR CIRCUITS FOR SHORT TO GROUND
  • Refer to Circuit charts in G4.
  • Using an ohmmeter connected to known good ground, check resistance of circuits.
Is resistance less than 10 K ohms?
Yes No SERVICE suspect circuit for short to ground. RESTORE vehicle. RETEST system. Circuits satisfactory. REPLACE trim cover. G6 TEST HEATED SEAT SWITCH POSITION 1
  • Disconnect connector C352 LH ( C356 RH).
  • Make sure switch is in position 1.
  • Using an ohmmeter measure resistance between Pin C352 , Circuit 1018 (LG/O) and Pin C352 , Circuit 1019 (T/LB).
  • Measure resistance between Pin C356 , Circuit 579 (BK/O) and Pin C356 , Circuit 580 (BR).
Is resistance between 2.0 K and 2.75 K ohms?
Yes No GO to G7 . GO to G14 .
Jan 07, 2018 | Lincoln Cars & Trucks
2000 Ford mustang 3.8 cranks won't start diagnostic gives code b1353
B1353 Ignition Key-In Circuit Open GEM Go to Pinpoint Test B .
PINPOINT TEST B: THE KEY-IN-IGNITION CHIME DOES NOT OPERATE CORRECTLY
Do you know what the GEM - genaric electronic control is ?
You need a scan tool to check ignition switch position .Don't know if this would cause a no start . Have you check for ignition spark and fuel pressure ? Are there anyother problems with power door locks or windows or lighting ? Thing's the GEM controls ?
CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK IGNITION STATES
NGS
Monitor the GEM PIDS IGN_KEY, IGN_A, IGN_S, and IGN_R while cycling the ignition switch through the OFF, ACC, RUN, START and key out positions.
  • Do the PID values agree with the ignition switch states?
Yes GO to B2 .
No GO to B4 . B2 CHECK GEM INTERNAL TONE OPERATION Trigger the GEM Active Command CHIME ON and OFF.
  • Does the chime operate correctly?
Yes GO to B3 .
No INSTALL a new GEM. For additional information, REFER to Section 419-10 . REPEAT the self test. CLEAR the DTCs. B3 CHECK GEM INPUT FROM DOOR AJAR CIRCUIT Monitor the GEM PID D_DR_SW, while opening and closing the driver door.
  • Do the GEM PID D_DR_SW values indicate CLOSED and AJAR correctly?
Yes INSTALL a new GEM. For additional information, REFER to Section 419-10 . REPEAT the self test. CLEAR the DTCs.
No GO to Pinpoint Test D . B4 CHECK GEM INPUT VOLTAGE FROM IGNITION SWITCH AT CJB FUSE 28 (15A)
CJB Fuse 28 (15A)
Measure the voltage between CJB Fuse 28 (15A), Pin 1, harness side and ground while cycling the ignition switch through all positions.
  • Is the voltage greater than 10 volts in the RUN and START positions only?
Yes GO to B5 .
No REPAIR the CJB. REPEAT the self test. CLEAR the DTCs. B5 CHECK GEM INPUT VOLTAGE FROM IGNITION SWITCH AT CJB FUSE 32 (15A)
CJB Fuse 32 (15A)
Measure the voltage between CJB Fuse 32 (15A), Pin 1, harness side and ground while cycling the ignition switch through all positions.
  • Is the voltage greater than 10 volts in the RUN and ACC positions only?
Yes GO to B6 .
No REPAIR the CJB. REPEAT the self test. CLEAR the DTCs. B6 CHECK GEM VOLTAGE INPUT CIRCUITS FOR OPEN - IGNITION SWITCH CIRCUIT 911 (WH/LG)
CJB Fuse 28 (15A)
GEM C352
Insert ignition key. Measure the resistance between GEM C352 Pin 8, Circuit 911 (WH/LG), harness side and CJB Fuse 28 (15A) Pin 2, Circuit 911 (WH/LG), harness side.
  • Is the resistance less than 5 ohms?
Yes GO to B7 .
No REPAIR Circuit 911 (WH/LG). REPEAT the self test. CLEAR the DTCs. B7 CHECK GEM VOLTAGE INPUT CIRCUITS FOR OPEN - IGNITION SWITCH CIRCUIT 1002 (BK/PK) Measure the resistance between GEM C352 Pin 22, Circuit 1002 (BK/PK), harness side and CJB Fuse 32 (15A), Pin 2, Circuit 1002 (BK/PK), harness side.
Yes GO to B8 .
No REPAIR Circuit 1002 (BK/PK). REPEAT the self test. CLEAR the DTCs. B8 CHECK GEM INPUT CIRCUIT FOR OPEN - KEY-IN-IGNITION SWITCH CIRCUIT 158 (BK/PK) Measure the resistance between GEM C352 Pin 9, Circuit 158 (BK/PK), harness side and ground.
Yes GO to B9 .
No REPAIR Circuit 158 (BK/PK) and key-in-ignition switch for failure. For additional information, REFER to Switch-Key-In-Ignition Warning . REPEAT the self test. CLEAR the DTCs. B9 CHECK GEM VOLTAGE INPUT CIRCUITS FOR SHORT TO POWER - IGNITION SWITCH CIRCUITS 911 (WH/LG), AND 1002 (BK/PK)
CJB Fuse 28 (15A)
CJB Fuse 32 (15A)
GEM C352
Remove ignition key. Measure the voltage between GEM C352 Pin 8, Circuit 911 (WH/LG), harness side and ground, and between GEM C352 Pin 22, Circuit 1002 (BK/PK), harness side and ground.
  • Are voltages greater than 10 volts?
Yes REPAIR the circuit in question. REPEAT the self test. CLEAR the DTCs.
No GO to B10 . B10 CHECK GEM INPUT CIRCUIT FOR SHORT TO GROUND -- KEY-IN-IGNITION SWITCH CIRCUIT 158 (BK/PK)
GEM C352
Remove ignition key. Measure the resistance between GEM C352 Pin 9, Circuit 158 (BK/PK), harness side and ground.
  • Is the resistance greater than 10,000 ohms?
No REPAIR Circuit 158 (BK/PK). REPEAT the self test. CLEAR the
Jan 03, 2017 | Ford Cars & Trucks
Transfer unit c352 change
open right side remove two screws which release locks one to the rear on to the front, pull belt assy out, install new one reinstall locks
Jan 27, 2014 | Konica Minolta bizhub C250 All-In-One...
I would like to teach me to scan the Bizhub C352, ie what are the steps to take to scan a document in BIZHUB C352. thank you Manuel Medina papelariapatrick@hotmail.com
Mack a scan folder on your computer & share it to network the you go on c352 and press scan key - direct input / scan to SMB / reference / work group open / your pc name open / scan folder ok -you are ready to scan any document any help you con- me 919899653281
Mar 19, 2013 | Konica Minolta Bizhub C352 Digital Copier
C3452 error code bizhub c352
Sir/ Mam,
If after this procedure the code comes back do not reset again, get a tech out and expect to pay for a new fuser unit, continue resetting can cause the fuser the hot part to catch on fire ruining a perfectly good day.
1. Turn OFF the Main Power Switch (Located in side front cover). (ensure Control panel power switch is on)
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Jan 10, 2012 | Konica Minolta Office Equipment & Supplies
I want to move a nordic track power tread pt5.0
HOW TO MOVE THE TREADMILL
Make sure that the pin
on the lock knob is inserted into the slot in the catch.
1. Hold the handrails as shown and place one foot against a
wheel.
2. Tilt the treadmill back until it rolls freely on the front wheels.
Carefully move the treadmill to the desired location. Never
move the treadmill without tipping it back. To reduce
the risk of injury, use extreme caution while moving
the treadmill. Do not attempt to move the treadmill
over an uneven surface.
3. Place one foot on the base, and carefully lower the treadmill
until it is resting in the storage position.
Oct 05, 2011 | Nordic Track NordicTrack Treadmill, A2550
Where do the staples go in a bizhub C352
Tha stamples go in a finiscer cover, you have to open front finiscer door and, on the left you can see the stample unit. Stample unit, in normal condiction, is positioned indoor, but you can move it by lcd dysplay funcion (stample chage) or in manual mode by rotation the green herness (stample movement).
Sorry for my bad english.
Bye.
May 14, 2009 | Konica Minolta Office Equipment & Supplies
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Dryer gets hot to the touch
If you didn't install new venting I'd start by checking the vent hose from the back of the dryer to the outside vent hood to make sure there is no blocked airflow. Could be something else but that is where I'd look first. Good Luck.
Jan 15, 2009 | Frigidaire GLER331A Electric Dryer
3,968 people viewed this question
jasbo
jasbo
