Question about RCA Televison & Video
The screen is showing a double screen and the color is like a rainbow. what can i do to fix this problem?
  • 4,234 Answers
This is a convergence problem. Can you post the model number please? With that I can provide you with some repair options.
Thanks,
Dan
Posted on Jul 29, 2008
How to fix my g1 rainbow screen, when i turn on my g1 phone it shows rainbow color screen
Hey!
If your screen is wrecked you might have to put your phone into your local phone repairer if you are still under warranty. But if you aren't covered you might have to buy a replacement screen and a how to install video should be on YouTube.
Hope this helps!
Dec 08, 2010 | HTC G1
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Aug 11, 2010 | Aiwa TV-S2011 20"
Double screen and rainbow like colors
my media player does not play occur eror in error show capture video failed, show no sound device or show input is failed
Feb 27, 2010 | RCA Televison & Video
Rainbow showing up at bottom and top of screen creating double and triple vision
IM GUESSING ITS A LAPTOP SCREEN OR COMPUTER IT COULD BE SOME WATER TRAPPED INSIDE OF THE SCREEN LIKE CONDENSATION WHICH COULD MAKE A PRISM OF LIGHT LIKE WHEN YOU SEE A RAINBOW BECAUSE ITS SUNNY AND RAINING
Oct 08, 2009 | Philips TV Tuner Video Capture PCI Card -...
TV Colors gone like a rainbow
It's dignostic coil problem replace it
or moving maganent on screen when colors have gone
Mar 15, 2009 | Sanyo Televison & Video
TV Picture Distorted
You need new convergence ICs Call your locally tv repair shop or find someone that knows how to work on CRT projection tvs.
Aug 29, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Bent picture
Not sure if you fixed your problem already. But the answer is a color convergence problem. You can try adjusting manually via the remote and if that doesn't work it is most likely the two main IC chips that control the color convergeance. It is also possible that not only the IC chips have gone bad but also there are a couple of resistors that usually burn out with the ICs as well. They will need to be replaced. This isn't something that I would attempt on your own. Typically a TV technician will charge between 300 and 400 to fix at your house.
Mar 15, 2008 | Philips 60PP9363 60" Rear Projection...
Convergance problems?
did you adjust the convergence
on the menu?
Jan 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Televison & Video Logo
21 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
