Question about Kitchen Ranges
What can i use to clean my oven with. I have baked grease in the bottom of my oven. I need help
    Novelist:
    Champion:
  • 216 Answers
Greetings alleylori,
Most times a traditional cleaner like Easy Off will do the trick, however closely read and follow the directions as well as any safety precautions such as protecting your hands.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Posted on Jul 29, 2008
What can I do to clean my advantium oven besides soap and water? It just doesn't clean the baked on grease on the inside. Help!
Eay Off oven spray. Just spray it on and wait about 15 minutes. Then wipe off the grease with a bounty! It's that essy!
Apr 07, 2011 | GE Advantium 120 Convection/Microwave Oven
I have a new Frigedaire self cleaning oven. Before I got to read the manual my daughter baked a cake which dripped onto the oven floor and began to smoke. To catch more drips I put a pice of tinfoil on...
Greetings,
remove as much tin foil that is possible...use something like hot water and mild detergent to loosen up the baked on cake residue...this should come up ok with alittle elbow grease...then run your self clean cycle...All will be ok....Bruce Denton
Jan 20, 2011 | Frigidaire Ovens
MY OVEN HAS GREASE SPILLAGE IN THE BOTTOM. I WAS BAKING AND IT STARTED TO SMOKE. I want to remove the grease first before I start the self cleaning. What should I use to best remove the grease without...
best way to loosen grease in the oven area is to place an oven safe pan with some water in it and run the oven at 200 degrees for thirty minutes. This help in the removal grease without using anything but water.
Dec 17, 2010 | Thermador PRDS366US Dual Fuel (Electric...
Main problem, bottom two elements have conked out. Where do I get new ones? Next, how clean glass door when it won't come out of slots? Next, what do I use to clean shploops patina off crumb tray?
you can get the new elements from the online sites mentioned below www.repairclinic.com also from www.partsselect.com and for cleaning follow this instructions
  1. 1)take out a bowl and in that bowl make a paste using the baking soda and vinegar
    2)After making a paste open the oven door with the oven off. Take the sponge dipping it into the paste of vinegar and baking soda.
  2. 3) After dipping it into the paste. Smear it on your oven door. Leave on for about 10-15 minutes longer for more stubborn stains. Now the time is up! take that sponge rinsing it in water and wipe down. Little or no elbow grease is required. Now you have a beautiful oven door.
    This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Mar 04, 2010 | Bella Cucina 13049 1500 Watts Toaster Oven...
Foil on bottom of oven when I baked.
Take the bottom out and soak it. Use a good oven cleaner after tou soak in in hot hater for a while. You'll have to get between the foil and the metal, which has baked on grease.
Dec 31, 2009 | LG LRE30755 Electric Kitchen Range
How to remove grease splatter from toaster oven
set a bowl of ammonia in it over nite. do not turn oven on the fumes will ease the grease off. wipe clean in the morning with a dry cloth
Sep 18, 2009 | Oster 6058 Toaster Oven with Convection...
Need directions to clean my tappan oven
1. Add baking soda to a cool oven. Sprinkle a thick layer of baking soda onto the bottom of the oven. Make sure the oven is completely cool before you attempt to do this. 2. Spray the baking soda with water. Using a spray bottle, spray the baking soda down until it is damp, not saturated. The water and baking soda together will help break down the food particles. 3. Continue spraying baking soda as it dries out. Every few hours spray the baking soda down again to keep it moist. Continue this process over several hours, spraying water as the baking soda begins to dry out. 4. Scrape out the baking soda. Scrape the baking soda out of the oven. Food residue will be scraped out with the baking soda. 5. Rinse the bottom of the oven out thoroughly. Yes, you'll still have to rinse out the oven, but next time you cook your food won't have an added taste of oven cleaner.
If I had the rest of your model number I may find what Tappan now Fridgedaire Electrolux reccomends, but this is the least toxic. Have a great day..
Feb 08, 2009 | Tappan TEF242 Electric Kitchen Range
How do I clean my GE Advantium Microwave oven?
There are many good suggestions for cleaning and deodorizing microwaves here.
Jan 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Electric double stove
Some double oven models have only one that is self cleaning. If you do not have a cleaning button for the bottom oven, it is not self cleaning. The solution is to use the top oven for those messy baking or roasting chores and use the bottom oven for the clean baking chores.
Mar 26, 2007 | Kenmore 41389 Electric Double Oven
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
