Question about Gigabyte GA-8I845GVM-RZ Motherboard
Usb port ceases to work when any device connected to second port
I have gigabyte 845 chipset motherboard with 4 usb ports. Whenever I connect one pendrive, one printer it works fine. When I connect second device either printer or pendrive it dosent recognise. I should disconncect the first device to start working. I reinstalled the xp os sp2. Still same problem is persisting.
  • 54 Answers
Well, I'm assuming your speaking of a pair of ports either on the front or the back of your system. Most USB ports are paired (i.e. the ports on the front of your system are cabled into a single connector of your motherboard). What if you put the PenDrive in the front and the printer in the back? Another interesting alternative is that if you have any empty USB ports on the motherbard, use something like one of these to seperate and test your theory: http://goo.gl/K2VPu5 or http://goo.gl/VzRZMo. These are great for DIY server, NAS, or AIO where you boot off of a USB drive that otherwise would be hanging outside of the box. In your case though, this will be a test for your PenDrive in one while your printer is in another.
Of course, I cant help but wonder what we're missing here. Do you have a bad printer/USB connection or PenDrive? Is the printer drawing too much current?
Posted on Jan 07, 2015
    Scholar:
    New Friend:
  • 98 Answers
Your USB ports on your computer are plug and play. If you have issues with your USB port, it is port related, driver related or device related. The following solutions will help you identify the problem to resolve your USB port issues.
To Identify a Working USB Port
Begin troubleshooting your USB ports by checking Device Manager to see if your USB ports or hubs are working properly.
  1. Click the Start button. ClickControl Panel.
  2. ClickSystem and Maintenance.
  3. ClickDevice Manager.
  4. Double-clickUniversal Serial Bus controllersand check to see if all your USB ports, hubs and controllers are functioning correctly. Any devices not functioning will have a yellow exclamation mark in front of them.
  5. If Device Manager shows any USB ports, hubs or controllers are not functioning, check for updated drivers.
To Update the USB Port Driver
An out-of-date BIOS driver can create issues with your system recognizing the USB port.
  • Watch a Video on Steps to Update Bios on Your Computer.
    1. When the update process is complete, your computer will restart again to load the operating system with the new driver version installed.
Posted on Jan 05, 2015
All the usb ports works fine when one device printer or pendrive is connected. Suppose if I connect to usb 1 pendrive it works. If I connect printer to usb 2 it will not work. If I remove pendrive printer starts working in usb 2. Same thing happens in usb 3 & usb 4.
Posted on Jul 31, 2008
  • 84 Answers
As you stated the device works in one slot but not the other , tells you there is problem with that usb port , don't use those ports , best thing to do is purchase a PCI USB card if you need more USB ports .
Posted on Jul 29, 2008
Gigabyte ga-81848p775-g not working
which device are you referring to ?
it could either be a problem with leads / connection or missing drivers or something totally different
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
Oct 04, 2012 | Gigabyte Technology GA-81845PE-RZ Intel...
Problem with USB
Did you install the chipset driver first when you installed the operating system?
Aug 19, 2012 | Intel DG31PR Motherboard
Usb ports not recognised
Right click on the yellow flag and uninstall the corrupt driver. Restart the computer, plug a USB device in and it should be resolved. If not post back.
Regards.
Jun 29, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Usb port not supported
What is that is not recognized, the device or the port?
Please go into your Device Manager and delete all references to USB ... you will find them listed at the bottom. Reboot. Windows will install what it needs.
If it still doesn't work, are your devices USB1 or USB2? Are they big power hungry devices? Is your independent USB power supply operating?
If still nothing, you may consier adding a USB PCi card.
Thanks for your interest in FixYa.com
Mar 01, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
I cannot hear any sound
does ur sound device in Device Mgr has any IRQ conflict ?...are ur sound speakers connected to the correct sound port in the box
Jan 05, 2010 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Problem with Data storage devices
check the usb ports or drivers if those are your connecting port and get the right drivers from the MOB manufacturer
Dec 01, 2009 | Intel Computers & Internet
Usb port not working
try changing the settings in BIOS to high-speed USB speed support. Also physically clean the port of all dust(it happened to me and after washing it pure alcohol, the usb port started working)....sodeep
Apr 22, 2009 | Intel Motherboard
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
845 mother board. ps2 keyboard connection are not working.
do not connect power led r remove if connected i had the same problem and this was the solution
Dec 21, 2008 | Intel D845HV (735858149143) Motherboard
Problem with usb port
your usb slots are died,by a new usb pci card and install int the computer
Feb 08, 2008 | Intel Gigabyte GA-8I845PE-RZ 845PE chipset...
Gigabyte GA-8I845GVM-RZ Motherboard Logo
1,878 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
