Question about Dell Latitude D600 Notebook
It won't boot to the os
It seems to go through the bios setup, then comes up to a white and black screen that has 3 choices
it says "the device in the system modular bay cannot be identified. it
may not be completely inserted or may have some other problem. follow
the steps below,
1 make sure device is fully closed
2 press esc key wait for system to power down
3 press power button to retry detecting the device
well none of that stuff works, and then it just shuts down, i have nothing in any bay.
is the bios messed up, is the mobo bad? thanks in advanced! john
  • 3 more comments
  • airbrushjohn Jul 29, 2008
    thank you! very much! i will do that now! and i'll let you know!
    hi pyrhyc,
    i took the drive out and for some reason there was a small piece of paper about the size of a quarter jambed in the connector on the mobo. well i finally got it out! i have no idea how that got in there! anyway, i cleaned it all out as best as i could. but i still getting the same black and white screen. do you think the drive could be bad, as it does have warnings about it being sensitive about shock and vibrations.
    thank you very much for all your help! john
  • airbrushjohn Jul 30, 2008
    pyrhyc really helped me with the D 600 solution! thank you very much!
    hi pyrhyc,
    how do i rate you? everytime i press the fixya icon it goes to a page the says itcan't be found, and i am logged in and that page keeps saying i need to log in. thanks again john
    Genius:
  • 2,028 Answers
The modular bay refers to the optical drive (CD drive). There is a small screw holding it, I've had machines at my shop that this screw fallen out and the drive wasn't making a good connection. Be sure that the drive hasn't slid out a bit. Take it out clean the connection and put it back, making sure it's seated properly. Try this, then let me know, and we'll go from there.
Posted on Jul 29, 2008
  • 1 more comment
  • Ryan Rogers
    Ryan Rogers Jul 29, 2008
    It's a good possibility the with the paper being in there it shorted out the drive, or it could have damaged the connector or bent one of the contacts in the connector. Make sure that all the paper is out, and the contacts are clean and aren't bent. If these are good, then a replacement drive may be your only option.
  • Ryan Rogers
    You're welcome. Please don't forget to give me a good rating!!!
  • Ryan Rogers
    Ryan Rogers Jul 30, 2008
    You should just be able to hit the fixya icon. They've been doing some maintenance to the site recently, so it may be that. Try again later. Thanks.
How to giving boot with different ways to acer travelmate 2423 laptop
1) You can set your boot options in your bios, watch as you laptop boots, you should see something like "Hit F2 to enter setup". Hit F2, select boot options then choose to boot from CD, HDD or external drive. Take care because you don't want to mess up your Bios. So read the screen carefully before changing anything. When you're happy, select save and exit then reboot, you should then boot from the device of choice in the order of choice.
2) Windows boot options, windows has several options for booting from, including safe mode. To do this, hit F8 several times while the laptop is booting, you should come to a screen with the several options on offer.
Feb 12, 2012 | Acer Computers & Internet
No operating system found can't boot from usb there is no boot from usb option
Did you try pressing F8 key at boot up?
  • 1
    Turn on your laptop and look at the first screen that comes up as soon as it is on. This screen will tell you "Press x key to enter setup", replacing "x" with the actual BIOS access key. It's usually "Del" or "F2" on Toshiba systems.
  • 2
    Press the key firmly and quickly before the screen goes away. If you do not react quickly enough, you will miss the window of opportunity to enter the BIOS. On Toshiba systems, this window of opportunity is somewhere between two to five seconds.
  • 3
    Navigate your BIOS configuration screen to the "Boot" tab. It is usually just before "Exit."
  • 4
    As the first boot device, select "USB," or "USB HDD." If you have a "USB ZIP" option, you might be able to boot from it, so select that if you have no other choice.
  • 5
    Press the button for "Save and Exit" in your BIOS. The correct button is usually F10.
  • Read more: How Do I Get My Toshiba to Boot From a USB? ' eHow.com http://www.ehow.com/how_5970005_do-toshiba-boot-usb_.html#ixzz1hrx9qZ3j
    Dec 28, 2011 | Toshiba Computers & Internet
    Getting error nvidia boot agent 249.0542
    It seems the Basic Input Output System (BIOS) settings have been changed on this computer.
    This type of error message occurs when the computer is trying to seek a network device to boot from, or is set to boot from a removable disc or other media that have bootable files stored on them that the BIOS requires prompting or selection for in order to proceed to the boot stage.
    First check that there is no disc in the Optical (CD/DVD) Drive -> if there is remove it -> restart the computer by pressing and holding down the Control (Ctrl) and Alternate Value (Alt) keys 2 fingers of your left hand -> press the Delete (Del) key with your right hand -> release all 3 keys -> tap either the Del or the Function 2 (F2) key 2-3 times as the first white writing appears on the black background of the screen after powering up -> the (Power On Self Test (POST) procedure will then redirect to BIOS Settings (often referred to as Setup) -> use the keyboard arrows to navigate to Set Default Values -> press the F10 key -> press y for yes or Enter for OK -> test the boot process again.
    If the computer still does not boot properly repeat the above steps to enter the BIOS Settings/Setup again -> use the keyboard arrows to navigate to Boot Menu -> arrow down to Boot Device Order -> look at the BIOS Control Options at the bottom or side of the window to find the appropriate control keys for changing the order of the boot devices (often the + and - keys, the F5 and F6 keys, the Page Up [PgUp] or Page Down [PgDn] keys -> move/promote the Hard Disk Drive (HDD) to the First Boot Device position -> press F10 -> y for yes or press Enter for OK -> test the boot process again.
    Nov 20, 2011 | Acer Computers & Internet
    Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
    step one, big battery out? skipped that?
    step 2, a good power pack , that means 19vdc on those 2 pins.
    bingo BIOS screen now work ,yes?
    step 3, try an external VGA screen at the P15 VGA jack there
    screens work now (BIOS first) yes/no?
    remove DVD, drive
    and all USB devices
    there booting with only 1 memory stick. (got more?, try each 1 by 1)
    black screens of *****'.
    the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
    me the power park is dead.
    http://pcdied.com/#black-screens
    May 01, 2017 | HP Pavilion dv5020us Notebook
    I have installed windows 2000 server and i am getting problem in booting of os. when there is cd of ms2000 present in the cd drive the os boot properly while if i remove cd from the drive and start the...
    During the boot process you will see on the screen to press a certain key to enter setup
    Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
    (note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
    The BIOS is AMI. Under ADVANCED SETUP:
    The options listed for 1st,2nd ,3rd Boot device include:
    IDE-0 means Pri master ?
    IDE-1 means Pri slave ?
    IDE-2 means Sec master ?
    IDE-3 means Sec slave ?
    hope this helps
    Apr 15, 2011 | SuperMicro X6DVL-EG2 Motherboard
    I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
    If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
    Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
    I have an aspire one netbook windows 7 has stopped working after error msg i am left with a black screen and white curser, i know i need to reinstall os so I have bought an external unit to do this but all...
    to solve your black screen with just cursor
    1. disconnect all (external) devices on your netbook 2. remove battery and adapter then press and hold the power button to drain flea power for about a minute 3. put the battery and adapter back in. 4. power on (as soon as you hit power button tap "F8" key) 5. advance boot options>safe mode (after loading still black screen and just cursor: press alt + ctrl + del then access task manager - new task > run > explorer.exe (should bring up your desktop) 6. access system restore under start > accessories > system tools > system restore 7. restore to an earlier time
    to solve your re-installation of OS
    1. boot to bios by pressing "F2" or "Del" (depending on your manufacturer) 2. once in bios look for restore defaults 3. save and exit 4. boot options under "F12" highlight media drive press enter and continue pressing enter until you see windows loading screen
    Mar 23, 2011 | Computers & Internet
    My laptop is passing BIOS, then i get the possibility to choose my start up choise. no mather wath i choose, the sreen goes black, and a cursor appears. It does nothing anymore, even a live ubuntu cd...
    Remember, there are many things you can do which will make your Windows installation as well as your laptop unstable, or even make it so it will not boot. Try to get into your bios. Different computers have different ways to get there - some have it on the screen, such as "hit delete key toenter bios" or "hit f12 to enter bios" or some other key combination. I think you enter the bios on your computer by pressing F10 repeatedly while booting. You should get to the setup screen. See if your hard drive is listed. You should see a hard drive as well as a dvd drive. If your drive is not listed, either someone has changed your setup so it is not the boot drive, or your drive may have gone bad. While you are in the setup, if it is not already the first choice, make your dvd (or cd) drive the first boot device. If it shows up, make the hard drive the second choice. Then when you boot, the Ubuntu should load. Try not to make any other changes, as you can make your laptop unuseable.
    Aug 22, 2010 | HP Compaq nx9010
    How i can boot from a cd to install os
    1. Turn on your computer
    2. press the proper key in order to enter bios setup while black screen in progress. this key may f2 or f8
    3. investigate the boot device order
    4. set the cdrom as #1
    5. press f10 key to save and exit.
    6. put a bootable installation CD/DVD into the cd/DVD reader's tray.
    7. cut off the po-wer
    9. power on the computer
    if everything ok, the computer will check the cdrom device to boot and start booting from cd.
    Aug 18, 2010 | Toshiba Satellite 2060CDS Notebook
    How to reset the bios password for nec versa m350.. pls help!!! i want to reinstall my OS but i can't access the bios setup to change the settings to boot from cd rom upon startup. there is a bios...
    Restart the computer, and read the first message (white text on a black background), hoping that it says something like "press F1 to enter BIOS setup, press F12 to select boot priority".
    If it does, press F12, and then select the CD-ROM device as the "bootable" device.
    Jun 15, 2010 | Computers & Internet
    Dell Latitude D600 Notebook Logo
    539 people viewed this question
    Alun Cox
