Question about Vacuums
It does not pick up, there is no suction - Vacuums
  • lunawelding Dec 31, 2008
    the attachment works, but the main vac does not suc
  • VacuumHelp Jan 14, 2009
    I can hear the vacuum pick up but it is getting clogged somewhere and isn't producing in the bagless collection. Filters seem to be clean; the problem is elsewhere. HELP! I vacuum often. TIA
    Problem Solver:
  • 7 Answers
Check for clogs, or dirty & clogged filters on bagless,
Posted on Jul 29, 2008
Not picking up the wand works and there is a lot of suction there but when vacuuming the floor it sounds different and is not picking up
If it's not picking up when you're using the brushroll start with a new belt. Stretch belts lose elasticity because they are stretched to almost twice their original length to install them on the vacuum. They are very tight, and need to be to vacuum carpet thoroughly. While you have the brush roll out clean off any hair, yarn, string, dirt etc. check the suction tube to the power nozzle to make sure you have good suction there. If not try the determine what could be causing a restriction.
Dec 04, 2017 | Vacuums
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Royal carpet extractor not picking up water well
Try to follow the suction from the machine through the dirty water tank to the front floor suction piece. Make sure the dirty water tank is seated properly. Make sure there are no suction leaks any where.
Mar 21, 2014 | Royal Procision 7910 Carpet Extractor
Air not getting to hose
I'm not sure which model you have but this is good for Riccar upright vacuums. If the hose has good suction but is not picking up well check the suction tube that is down by the brush roll. The suction tube starts by the brush roll and goes to the back of the vacuum where you put the suction hose into. If it has a clog or restriction the vacuum will not pick up properly.
Mar 12, 2014 | Riccar Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Does not have any suction to pick up
Clean out the filter in the top of the cyclone chamber
Make sure there are no blockages in the tubes or hoses by checking for vacuum
May 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Not picking up dirt. hardly no suction
if your model has a hose for a wand or brush attachment then remove the hose and check it for clogs.
Jan 23, 2010 | Oreck XL Ultra Bagged Upright Vacuum
DC07 plenty of suction but not picking up
You have either stretched or broken the belt that drives the beater bar. Replace the belt.
Jim
Dec 03, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
WAND WILL NOT PICK UP - NO SUCTION POWER. CHECKED
Check out: http://www.dyson.co.uk/support/help.asp?model=SUP-DC14&article=527  and pick the suitable model that matches yours.
Mar 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Vacuums Logo
184 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
