Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
Door will not open on washer...after 24 hrs machine started....quit on rinse and drain cycle and will not restart.
Kenmore HE3T Front end load
First unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Posted on Aug 06, 2008
Kenmore elite HE3t front loading washer not starting
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Sep 26, 2012 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
HE3t Washer Problem -
Clean out the drain pump, if this doesn't resolve it then replace the drain pump,this will resolve you issue.f09 means slow drain or no drain.
Oct 30, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
Apr 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore washing maching door is not opening
Hold in "end of cycle" for 3 seconds. Or if you have a pic of a "key" on one of the buttons, hold that in till the lock signal goes off.
Feb 22, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Oder inside washer
On newer other machines, there is a cleanout cycle that uses 2/3 cup of bleach, no detergent and I believe uses more water. Suggest you use a load of white towels, no detergent, the bleach and put it through a normal or soak cycle where the bleach has a chance to kill off the germs and other bacteria, then rinses itself clean. They also recommend that the door be left open on these machines to allow the moisture to clear and dry assisting in curtailing further development of the same. The cleanout procedure they present is suggested for monthly using their special cycle which doesn't exist on my HE3T either. Hope this helps some. NOTE: There are cautions about leaving the high level of concentrations in the washer for extended periods or too often.
Sep 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
222 people viewed this question
Sal De
 Brian Main
Brian Main
