Question about Microwave Ovens
Maytag Microwave Model 5200 - need plastic rotating ring
We need a new rotating ring for our Maytag Model 5200 Microwave. Cany you help?
  • Anonymous Mar 08, 2009
    The plastic rotating ring of my Maytag Microswave Model 5200 was broken too.
  • Microwave Ovens Master
  • 8,934 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
But it needs to be the full model number, not the partial you show in your post.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Posted on Aug 02, 2008
Model # UMV1152BAQ,S/N 10406839EN Linkage to
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is W10207571 (listed as item 22 in the parts drawing under the "Internal Controls" parts section.
NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common procedure.
Apr 20, 2011 | Maytag Appliances Over-the-Range Microwave...
We have a MMV5000 BDW and the turntable has stopped turning
repairclinic.com
Apr 05, 2011 | Maytag MMV5156A 1000 Watts Microwave Oven
Plastic peice that fits under plate inside micowave that makes it rotate
If the model number you have this question listed under is correct, there are two possible parts based on your question. There is the carousel ring, that turns the glass tray, and there is the small plastic coupler that the center of the glass tray is supported by. The part numbers are as follows:
Carousel ring - WB06X10513
Coupler - WB06X10564
You can view and excellent exploded view diagram of this microwave at pcappliancerepair.com. The parts I mention are listed under Diagram 1151005 as items 84 and 101 respectively.
To replace the coupler, you simply remove the glass tray and gently pry straight up. The coupler will pull off of the turn table motor shaft. Insert the new coupler and press on to the shaft.
If this is not the correct model number, please post back with your correct information so that I may be able to provide you with better assistance. I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Maytag microwave makes a loud sound and it stopped rotating (I have turned the rotator on several times).
this is due to the magnitron tube is arching and there is possibly grease or dirt around it .You may need to replace the microwave. The drive for this model may be belt driven and the belt is worn and slipping. Repairs for this is usually a lot more than a new microwave.
Aug 05, 2009 | Maytag Microwave Ovens
Broken rotating microwave arm - can't find part
That would be the support, and you can find it by entering your model number UMC5200AAS here.
Nov 22, 2008 | Maytag UMC5200AAS Microwave Oven
Where to get parts
The roller ring is Maytag part # 53001024. Check with www.microwaveglasstrays.com or call them toll free 1-877-894-0035.
The part is in stock at a cost of $16.40 plus shipping.
Jul 18, 2008 | Maytag MMV5156AAS Microwave Oven
Microwave Handle Replacement mmv5156aas
Normallyyou have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jun 02, 2008 | Maytag MMV5156AAS Microwave Oven
Maytag MMV1153BAW
This is the stirrer cover. It is important. It is to keep food particles and grease out of the stirrer and waveguide area.
If grease or food particles build up, they can arc, which will cause burn damage to the cover, stirrer, chassis, and/or magnetron.
If you have any arcing, you should remove it for cleaning. Be careful of sharp edges.
The stirrer's job is to stir the microwaves to ensure even heating, even when a turntable is not present or not used.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 05, 2008 | Maytag MMV1153A Microwave Oven
Rotating ring/ Glide tray comes off the track -Elite Model 80803
Take your round glass tray and plastic three wheeled hoop to a local Sears store, open up the microwaves on display, find the one that is still using something similar, deftly trade out yours for theirs. The new wheeled plastic hoop wheels are slightly bigger and the glass tray raised guides are a bit longer, since the switch no problems like I had. Don't get caught. They do not have those parts for sale at the local Sears store.
Feb 20, 2008 | Kenmore 80809 Microwave Oven
Microwave Ovens Logo
114 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
