Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover SteamVac Model F5887-920 - hand attachment won't spray
The upholstery attachment will ****-up water but cannot get it to spray from it . The main unit will dispense but is inconsistent in picking up the dirty water (the red ball pops up and loses suction). I do not see a foam filter on the reservoir that was spoke about on other posts.
I have a model I got in 2001. I found that the water sprayer on the hand tool is driven by a little turbine that relies on suction from the main vacuum motor. I eventually found that the spindle inside the turbine had separated and hence the hand-tool wouldn't spray. I glued it together but that only fixed the problem until it broke again. I am going to buy another (about $23).
Posted on Aug 04, 2008
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I took my nozzle apart on my hoover steam vac because it leaked water all the time, now I cannot get the back together
The Hoover SteamVac is an upright, self-contained carpetcleaning machine. The machine features five rotating brushes and on-boardstorage for a hand-held upholstery tool with an 8-foot hose. But itis not that much difficult to re-attach the Hoover SteamVac nozzle. Here, a weblink, with full procedure and diagrams, which will help you to re-attach iteasily - http://hoover.com/file/624/. Hope this will help you. Good Luck.
Aug 18, 2011 | Vacuums
Water leaks out under the unit when using the upholstery attachment?
You may wish to check and see if the leak is where the small water supply hose is plugged in to the cleaner base. That connecction supplies water from the product, to the spray end on the upholstery hose.
Sep 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover steamvac turbopower 5000ls will not spray for hand tool
my turbo 5200 will not pick up the moister into container to dry does anyone know what the problem may be
Sep 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover model 5870-900
you dont have the lid on correctly, if you can lift the lid up, then you have it on incorrectly.
Jul 20, 2009 | Hoover F5870-900 SteamVac Vacuum
Attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Jan 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
841 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
