Question about Adobe Photoshop CS3 10
Need help i've encountered adobe photoshop just now... i mean, this is my 1st time to have an attempt of using it as a picture editor.would you like to give a good tutorial website for a beginner like me? thanx a lot. **, -april-
  • 876 Answers
Adobe Photoshop comes with a tutorial site. and there are many on the net available. Just go to google and type in the word Adobe photoshop tutorial. Here is one:
http://www.photoshopsupport.com/tutorials.html
Have fun. There are many sites you can go to for info. Please rate this solution and Thank You for using Fix YA.
Posted on Aug 21, 2008
I need a serial number for adobe photoshop elements11
If you lost your serial number, you can contact Adobe support to retrieve it. Otherwise, you need to purchase the software in order to receive a serial number.
Picture editor edit pictures Adobe Photoshop Elements 13
Learn Support
Nov 17, 2014 | Computers & Internet
I need adobe photoshp 7.0 serial number
7.0?
I've you mean the latest version (CS5), than you need these serials.
Adobe Photoshop CS5 Extended SERIALS serial number CS5 32/64 bit versionshttp://www.filesonic.com/file/1108163441/APCSE.doc
Jun 12, 2011 | Adobe Photoshop 7.0 for PC
Every time I try to open the program, I'm getting this: Adobe Photoshop Elements 6.0 (Editor) has stopped working. Windows can check online for solution to the problem. Check online for a solution and...
Do Solution 1 first, then try Solution 2. Proceed to Solution 3 only if you wish to operate your device directly from within Photoshop or Photoshop Elements Editor.
Solution 1: Disable the TWAIN plug-in. Photoshop and Photoshop Elements Editor do not load plug-ins whose file name begins with a tilde (~). Rename the TWAIN plug-in to prevent Photoshop and Photoshop Elements Editor from loading it.
To disable the TWAIN plug-in:
  1. Do one of the following:
    • If you are using a 32-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    • If you are using a 64-bit edition of Windows:
      Photoshop CS4: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS4\Plug-Ins\Import-Export\
      Photoshop CS5: Navigate to C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-Ins\Import-Export\
      Photoshop Elements 6.0 Editor: Navigate to C:\Program Files (x86)\Adobe\Photoshop Elements 6.0\Plug-Ins\Import-Export\
    Note: If you do not know which edition of Windows you are using, see Determine whether your computer is running a 32-bit or a 64-bit edition of Windows (kb407673).
  2. Rename Twain_32.8BA to ~Twain_32.8BA. (You may not see the filename extension .8BA.)
When the TWAIN plug-in is disabled, you cannot operate your device by choosing File > Import > [Device name] in Photoshop or Photoshop Elements.
If you do not wish to operate your device directly from within Photoshop or Photoshop Elements, then you can use other software -- such as the software that came with the device, the Windows Scanner And Camera Wizard, or Windows Photo Gallery -- to operate the device and save image files from the device. (For instructions, see the documentation for the other software.) Then you can open those files in Photoshop or Photoshop Elements.
Solution 2: Disable older scanner files in Windows. If Solution 1 does not solve the problem, open the C:/WINDOWS/Twain_32 folder and move all files in that folder except the wiatwain.ds file to another location. Older scanning files in this folder can cause problems with more recent drivers and applications.
If you would like to operate your device directly from within Photoshop or Photoshop Elements, then proceed to Solution 3.
Solution 3: Troubleshoot installed drivers and re-enable the TWAIN plug-in. If you use a scanner, all-in-one printer, or another TWAIN-compatible device on your system, then the device's driver may be out-of-date. Download the latest version of the driver for your device from the manufacturer's website. Follow the manufacturer's instructions to install the driver. (If you have more than one TWAIN-compatible device, then download and install the latest driver for each device.)
After you have installed the latest driver for each device, re-enable the TWAIN plug-in and restart Photoshop or Photoshop Elements.
To re-enable the TWAIN plug-in:
  2. Rename ~Twain_32.8BA to Twain_32.8BA. (You may not see the file name extension .8BA.)
If Photoshop or Photoshop Elements successfully starts with the TWAIN plug-in enabled, then you can operate your device by choosing File > Import > [Device name].
If Photoshop or Photoshop Elements fails to start, then the driver for one or more TWAIN-compatible devices that you no longer have or no longer use may be causing the problem. (A driver will remain on the computer even after you disconnect a device.) Identify each device that you do not use, and then follow the manufacturer's instructions to completely remove each device's driver.
After you remove the driver for each device that you do not use, restart Photoshop.
If Photoshop or Photoshop Elements still fails to start, then the driver for one or more of the devices that you currently use is incompatible with the TWAIN plug-in. In that case, disable the TWAIN plug-in (see Solution 1: Disable the TWAIN plug-in) and leave it disabled. (You may also wish to periodically check the device manufacturer's website for driver updates. If an updated driver becomes available, then repeat this solution.)
Jul 31, 2010 | Adobe Photoshop 6.0 for PC
I need authorised code ,any body help me.............
have you tryed Adobe Photoshop support, here is the link :
http://www.adobe.com/support/photoshop/
Ask them for the code, they can help you
Hope thats help :O)
Please rate my answer
NB if you need a free editor like Photoshop, try Gimpshop, you can get it here :
http://www.gimpshop.com/download.shtml
have a nice time over there :O)(o:
May 18, 2010 | Adobe Photoshop CS3 10
Picture editor
Hi there and welcome at Fixya, the support team (lfete)
Adobe Photoshop is a purchase (Shareware) program, you need to pay for using it, but I mean it has 30 days Trial.
You can get the program Gimp which is FREE and you NEVER need to purchase you can get it here :
http://www.gimp.org/windows/
Here is the portable version you can have on a USB storage, so you can take it with you and use on every computer (Gimp portable):
http://portableapps.com/apps/graphics_pictures/gimp_portable
If you are NEW/just started to editing pictures I RECCOMEND Picasa which is also FREE and more easy to use. You can get it here :
http://picasa.google.com/thanks.html
Other FREE picture editor programs:
1. Irfan View, you can get it here (I use this :O)):
http://download.cnet.com/IrfanView/3000-2192_4-10021962.html?part=dl-IrfanView&subj=dl&tag=button
2. Gimpshop , you can get it here (nearly like Adobe Photoshop, but FREE):
http://www.plasticbugs.com/blogimg/GIMPshop_0.1beta_Setup.exe
3. Photoscape you can download it here :
http://www.freewarefiles.com/Photoscape_program_33600.html
4. Tintii Special picture editing program, you can download it here :
http://download.cnet.com/3001-2192_4-10730284.html?spi=2761da2b885537fae6abf31db56494ae
One last thing !! here you can find many many FREE programs (no purchase):
AND there is a lot more of "free picture editing programs" if you google it, I did Google it for you here:
http://tinyurl.com/y8g82v7
OR you can use Google by yourself here :
http://www.google.com and type : free picture editing programs
Hope it helps
IF NOT then try to return here
Have a nice time over there
Feb 08, 2010 | Adobe Photoshop 7.0 for PC
What does attempt to access invalid address mean in Adobe Photosh
Please turn your antivirus software to gaming mode and problem will be sovled.
Nov 17, 2009 | Adobe Photoshop Elements 4.0 plus Premiere...
Photshop elements 6 organizer dont start
i am an employee of adobe, I am aware of this issue, iam sendiing you an adobe engineer designed link to reslve this issue. i would suggest you to follow the given steps in detail:-
Please try this link:-http://go.adobe.com/kb/ts_kb406966_en-us
Sep 19, 2009 | Adobe Photoshop Elements 6: Windows
Photshop Elements 7 editor won't open
Are you trying to use it with a tablet device? Because some tablet devices override the drivers that are dependent for Photoshop. If this is not the problem, please leave a comment and I'll get back to you =)
Jul 16, 2009 | Adobe Photoshop 6.0 for PC
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
PhotoShop Elements Organizer problem
I am having the same problem, someone please help I have about 4,000
pictures my self
Jan 11, 2009 | Adobe Photoshop Elements 6: Windows
Adobe Photoshop CS3 10 Logo
90 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
