Question about RCA P52926 52" Rear Projection Television
RCA MODEL P56740RG
THE POWER COMES ON THEN GOES OFF JUST AS SOON AS IT COMES ON
  • ammora_moudi Aug 05, 2008
    i turn on the tv the powe come but the moniter not work see an ic burn but i dont know it number because its burn all of it
    Champion:
  • 230 Answers
Provide location part number. and chassis number too. Thank you !!
Posted on Aug 13, 2008
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
RCA model D52w23- Power light comes on for about 10 seconds then goes off. No picture, no sound. Power supply? Thanks. Jeff
I'd check the lamp first. No apparent reason to suspect the power supply, unless you didn't mention other symptoms
Apr 21, 2010 | RCA D52W19 52" Rear Projection Television
Rca d52w14 power light comes on briefly then goes
1. the supply had a fault and needs to be repaired or replaced.
2. www.partstore.com might have your supply or you can pre order it from them.
Good luck hope this inforamtion does help when it doubt get a service guy to come out.
thanks and please rate.
Aug 22, 2009 | RCA HD52W58 52" TV
RCA TV wont come on
if your tv 52" silverish color hd model,problem is on power supl.deflection module(module is on left hand side),famos for number of problems,importent to indicate if green light on front panel comes on and goes off in 3-5sec.if not tv has bad fuse(put 8 amp) if blows as soon as plug it in-bad diode on the same with fuse module.
Jun 10, 2009 | RCA 32F531T 32" TV
RCA Model D52W20B Serial # F074C312B Chasis ITC222 Set does not turn on the power light comes on then flashes and goes off. I need the part number in order to fix the problem
if the light flashes three times then goes out you need flyback 259296 if the light only comes on once then goes out you need the deflecion board. You can get any part you need at the following link and if your not sure leave them a email with the model number and symptom they respond quickly.
http://servicemanuals.vstore.ca/
Sep 25, 2008 | Televison & Video
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA P52926 52" Rear Projection Television Logo
18 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
