Question about GE Refrigerators
Temp gauge on refrigerator not come on - GE Refrigerators
  • GE Master
  • 19,396 Answers
  • Ginko
    Ginko Jul 29, 2008
    Generally it can be something wrong with thermostat or with the water pump. Is the fridge over heating, can you see steam coming out from back of the fridge ?
How do you put in 410a into Ac unit
You turn system on to cool setting and run temp down until outside unit comes on. Then you connect your suction side of your gauges to the suction side of your outdoor unit. Next you connect the liquid(high)side of your gauges to the liquid line on your outside unit(the little copper line). Connect the middle hose of your gauges to the 410a drum of refrigerant. Before opening the suction or low pressure side of the gauges you need to turn the drum upside down and turn drum of 410a on. Then you need a temp reading meter and clamp to read the temp of your liquid line(small line). While charging you want to make sure to release refrigerant slowly. The unit should call for a specified subcooling on unit plate. 7 to 10 degrees. You take the liquid line temp and subtract it from saturation temp on the high side of your gauges.(it'll be the pink numbers on the right side of your gauge.
Jun 05, 2013 | Heating & Cooling
Temps not holding on make table Traulsen prr120vpswe1 would like to no factor pressures for ref and settings on equipment
Pressure is dependant on the temp of the air at the condenser. If you put a manifold gauge set on it, and know the ambient temp, I am sure that you will find that it is low on refrigerant.
Mar 29, 2013 | Refrigerators
My refrig temp guage 107 degrees. I know it's not!! What to do??
Get a thermometer and place inside the refrigerator, to determine if you really have a problem with the cooling or if you have a faulty temp gauge.
Jan 22, 2013 | Kenmore Refrigerators
RFefrig temp registers 107 degrees. ?????
Place a thermometer in the refrigerator to get the true reading and make sure if it is a cooling problem or a temp gauge problem.
Jan 22, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Add freon to 2003 audi A8...any special tools needed? I have gauge and equipment but system will not take freon on the high side.
NEVER attempt to add freon on the HIGH side...This is very dangerous and can result in injury and damge to the system! The correct set of AC manifold gauges are needed to monitor pressures and determine the overall condition of the system...Refrigerants should be added by trained refrigeration technicians.
Jul 16, 2011 | 2003 Audi A8
I have A Subzero 690 and the water no longer comes out as cold
the water container is located on the fresh food side. This is how your water is cooled. I would get a Temp Gauge and put it in the fresh food side to see if the temp is correct.
Aug 11, 2010 | Sub-Zero 690 Side by Side Refrigerator
Freezing my lettuce in crisper , so how do i change the temperature so my vegetables don't freeze. i do not have a producy manual.
Magtag has dropped the ball on this one... The temp at the top and the bottom of the units are varied. Try turning your temp gauge down just a fraction until the lettuce doesn't freeze. I also suggest getting a temp gauge (cheap) and placing on your top shelf to monitor. Temp should be around 40 degrees.
Aug 22, 2009 | Maytag Refrigerators
Air conditioner cluch and cooling fans will not work unless you jump out the relays
prop. because the refrigerant level is to low and the low preasuer switch is not sending the ok signal to the relays to energize them check the refrigerant level with a gauge set first and record the temp out side aswell because all refrigerant will have a preasuer diferential depending on the temp.
Jul 19, 2009 | Heating & Cooling
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
