Question about Friedrich Heating & Cooling
My Friedrich P-09 manual states that to use condensation pump to press both temp and temp- at the same time,when the unit is powered on and the water full light is lit. When i push those keys however it merely locks the controls. How do i operate the condensation pump.
I have the same problem; pressing both buttons does not start the pump. Besides the "water full" light comes on almost after an hour of operation and I'd need to get up and drain manullly. Not getting any sleep.
Posted on Jul 21, 2010
On a Friedrich in wall AC/Heater in the heat mode in the digital display while the unit is working fine I get a flashing 08 alternating with the temp of 74. Model # PDE15K5SB-A is this a trouble code
This is an error code for "Unit cycles more than 9 times per hour". The service manual says the possible causes are "Unit oversized" and "Low load conditions".
Jan 10, 2015 | Friedrich Heating & Cooling
How do I turn off the check filter light on my Friedrich SQ08 window unit?
Friedrich window units should reset by pressing both the up & down temp buttons simultaneously. Had this issue for a while until I finally called the help center. For some reason couldn't find this info anywhere online. Hope this helps !
May 18, 2014 | Frigidaire FAC127S1A Air Conditioner
Pentax water pump
If the pump runs manually as you state, then the problem probably has to do with the control for the pump. It could be a bad capacitor in the control , but I'm not sure there are replacement parts for these control units. Possibly you need a new control unit.
Mar 21, 2014 | Flotec 3-Wire Submersible Pump - Fp3332-09...
Show drain hole on bottom of Friedrich window unit
it gets rid of condensate by a slinger ring on fan motor throws it up on condensor and evaporates it.
Oct 09, 2013 | Friedrich QuietMaster KM24L30 Wall/Window...
We have a Sairon Air conditioner and we don't have the manual. How do we set the time on the remote control so we can use the auto start function? Also we are wondering how to use the heat...
Press clock. time will start flashing. Now press < or > until required time. Then press Set.
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position.
Jan 16, 2011 | Friedrich QuietMaster SS12L10 Air...
I have a friedrich window unit el25j35. the heat went out last night
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 08, 2011 | Friedrich EL36L35 TwinTemp® 36000 BTU...
I have a friedrich ductless split m# mw24cy3f .. call for cool only fan runs inside, call for heat nothing runs, outdoor temp at the moment is 38 degrees, error code light blinks on indoor unit......
not able to find the error codes for the unit number you gave but, here is a number you can call to get them. sorry not more help.
1-866-793-0323 spacer.gif Mon - Fri 9:00am to 6:00pm EST
Dec 20, 2010 | Friedrich Heating & Cooling
Friedrich KStar KQ06J10 Air Conditioner not Cooling?
mcdevito75 here, Put the fan on and wait 3 minutes, NOW turn to low cool and place temp to 0 degrees or 1/2 thru the blue section of the cooling knob. Unit should work fine. type in online the unit name plus.com for any other assistance manuals, etc.
Jun 22, 2010 | Heating & Cooling
Heating & Cooling Logo
142 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
