Question about Sony Cyber-Shot DSC-P32 Digital Camera
Cybershot DSC-P32 need to change image size ?
My camera recently lost its zoom and it was doing pictures that are huge like ....800K to 1.4M instead of the usual 150K or less....which i can easily email and download to web if needed onto online pages....
I saw similar problem online for another similar brand of Cybershot but i do not think i'm able to fix it....i even went to Best buy twice and they made me buy a bigger memory card but it did not fix the problem. I went back to another location of Best Buy and they do not know how to....
Kindly help if you do - by posting back or emailing....
Thanks much,
Linus
  • nerdgirl895 Aug 05, 2008
    Can I get a better answer than initializing/reset? Like how do I do that? Thanks!
  • 10,594 Answers
Just reset/ initialize the camera so, it will go to default settings.
Posted on Jul 29, 2008
How do i the camera to take smaller pictures and if it is by using the zoom do I zoom in or out.. Thanks
Hi sportingnut4 ,
Thanks for the question ,
  1. If you mean by smaller pictures i.e. small in area you have to capture the images keeping the distance in perspective.
  2. If the distance between the image and camera is more , you would find the object being captures is small and if the distance is less , you would find that the object that has been captured is bigger.
  3. If you want to capture an object which is far away you can use the Zoom In function which would zoom your camera's lens in the object.
  4. If you have already Zoomed in , then to decrease the zoom i.e. to go away from the object as if you are increasing the distance between the object and the camera , you should Zoom out.
  5. Remember , Zoom out usually only works when you have already used the Zoom in function of the camera.
Hope this helps.
May 11, 2011 | Sanyo VPCE890 Digital Camera
I CAN NOT TRANSFER PICTURES FROM MY OLYMPUS CAMEDIA ULTRA ZOOM C2100 TO MY NEW PC, BECAUSE I LOST MY SOFTWARE CD.
You can always use a separate card reader instead of the camera for downloading pics. Then, you don't need any special software. typrice_19.jpg
Nov 10, 2010 | Olympus Camedia C-2100 Ultra Zoom Digital...
My 10 year daughter tried to delete a picture she didnt like. She pressed the wrong button and erased all frames by mistake. All our wonderful holiday pics gone ! is there anyway of getting these back -...
If she only deleted them instead of formatting them, there are expensive software programs that can retrieve the pictures providing you didn't keep adding more pictures to the card.
Aug 18, 2010 | Fuji FinePix S602 Zoom Digital Camera
The lens won't close
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 27, 2010 | Canon PowerShot A540 Digital Camera
How to zoom in ...make subject bigger...less far away?
to zoom in on a subject you push the t button you can get the manual at this link http://shop.ebay.com/i.html?_kw=Canon&_kw=PowerShot&_kw=A95&_kw=Digital&_kw=Camera it will be gone in one day 99cents good luck have a nice day!! :)
Apr 02, 2010 | Canon PowerShot A95 Digital Camera
Macro in sony W170 digital camera
The resolution of the photo you take determines how grain shows up as you zoom into the Photo, So taking a 10 megapixel photo on optical zoom or no zoom will give you a sharper picture than when you use both the optical and digital zoom to grab your picture. The digital zoom uses the centre of your CCD picture imager rather than the whole CCD so with less elements to your picture when you take it gives you blockiness sooner when you zoom in on the image. I am guessing your friend has digital Zoom turned off in settings to prevent the Graining showing upon magnification. Good light and a steady camera will give you the best results.
Dec 05, 2017 | Sony Cyber-shot DSC-W170 Digital Camera
Lost c-370 olympus cam driver
IF you are using Xp , just plug in camera with USB lead . Open MY COMPUTER find the icon for the camera( usually found after the DVD/cd drives ) adn just drag or use the move command to move the requiredfiles to where ever you want . I NEVER use the Olympus software too long winded . Hope it helps :)
Apr 25, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
ZOOM problem
Most likely there is a problem with servo drive for the lens and camera functions. The fix is to replace the complete processor board including the servo drive electronics. After replacement the board must be tested and calibrated.
Call Sony to see if the camera is worth to have serviced.
Jerry G.
Apr 06, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Samsung 800k digimax camera
If you're using a memory card, I recommend investing $10 and getting a USB memory card reader. It's much easier than trying to troubleshoot connection issues. Most can read just about every format. Plug in your card and connect the reader to your PC. It will see it as a drive and you can easily move your pictures over with a simple drag and drop. And it keeps your card healthier that way as well.
J. DeRuvo
Digital Camera HQ
Dec 01, 2007 | Cameras
Digital Zoom Problem
Three things: First, it is possible to disable the digital zoom feature on your camera. See the attached picture for instructions on how to make sure that digital zoom support is turned on. Second, digital zoom is only supported when you have the LCD turned on. Third, digital zoom isn't really a zoom. It is simply taking a smaller picture, and then stretching it out. Instead, you should take the picture with no zoom, then crop the photo using your PC to get it to the size you like. Keep in mind that digital zooming and cropping are technically the same thing. Both lower the amount of information you are capturing, and both will reduce the overall quality of the photo when you print it. I recommend Preclick's photo organizer (for Windows). It is free and can be downloaded from www.preclick.com.
May 16, 2007 | Canon PowerShot A85 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
67 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
